Hi guys will this rad fit in the front of the antec 900 if all drive cages are removed?
I did a google search for Antec 900 water cooling and it seems like a 2x120 is what everyone was putting in the front of the case.
How many drive bays does the case have??
It would take a minimum of 9 drive bays provided you had some extra room at the top.
Ok so i went back and looked at the case and it appears you can put one in the front but not sure where you would have room for a CD drive or HD's
24/7 Work & Play Rig
Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
It would be a very tight fit, because the MCR320 is 410mm, which is if my measurements are correct the height of the drivebays. You'll probably have about 5-10mm to spare.
Chuck 1 of these in? http://www.aquatuning.co.uk/product_...Schrauben.html
~Bex
PROJECT :: The Xtreme (WET) Dream!!!
PERSONAL H2O BESTS :
E8600 @ 4.8GHz E6750 @ 4GHz QX9650 @ 4.6GHz i7 920 @ 4.6GHz
PERSONAL AIR BESTS :
Sempron140 @ 4Ghz (Stock Cooler) i7 3960x @ 5.4ghz (Air Cooler)
Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
Swift_Wraith : "could someone please check bex for a penis?"
Circles SucQ!
Interesting rad. Probably performs ~ 2.5x120?
How much cutting you willing to do? I am about to put 2x320's in a 9 bay case
- similar to this one: http://www.xtremesystems.org/forums/...light=paraflow
But as Major pointed out - no room left for drives.
it works but it isnt exactly pretty.
Circles SucQ!
Sjeesh guys, try to keep your kinky stuff to the bedroom, kay?
I dont care if its tight qs long as it fits.And also will a MCW60 Rev2 fit on the 5970?
malik22: Probably will, and probably you gonna need two of them of course. I haven't heard of unisink for these cards, so probably you'll need separate mini heatspreaders for ram/mosfet chips. And if you haven't already bought MCW60s, you might get MCW80, it's newer replacement.
