+ Reply to Thread
Page 10 of 12 FirstFirst ... 7 8 9 10 11 12 LastLast
Results 226 to 250 of 280
Thread: Hackintosh
  1. #226
    Xtreme Member Raiden's Avatar
    Nov 2009
    Portugal
    0
    Quote Originally Posted by davidkozat View Post
    the detailed instruction are above in a step by step post I made; you got to burn the image inside Lion called InstallESD.dmg inside the folder Sharedsupport, with the Disk Utility on mac.
    Ill make a Video on How to do it on a Mac later on the weekend too busy at work right now.
    Good luck!!
    Thanks already burned it but says i cant install this using tiger, if i format the disk will i be able to install Lion?
  2. #227
    Hackintosh Lover davidkozat's Avatar
    Aug 2009
    Between London & Eastbourne, United Kingdom
    10
    Yeah you have to boot from the DVD so back up your data, and then insert the DVD restart your laptop hold the option key (alt) and boot the DVD then wipe your HD and install like any OSX.....
    Why Not Try a Hackintosh for A Change?? Steps HERE!!
    Want to installing Mountain/Lion from a DVD or USB on you Apple PC?? Steps Here!
    OLD RIG
    HAF 932 Modded Case
    http://img192.imageshack.us/i/img0416nv.jpg/
    http://img502.imageshack.us/i/img0417w.jpg/
    MB: Asus P6X58D-E
    CPU: Core i7 950 @ 4.2 Ghz @ 1.336
    RAM: 24Gb DDR3 Corsair @ 1600 7-7-7-20-1T
    GPU: 480GTX 700/1400/1848 @ 1.038
    HDD: 4 Tb Raid 0 Data
    SSD: 4 X 120 GB Agility 3 RAID 0 OS Win7/Lion Speed
    Super Stable aKa 24/7
    Winners of EURO 08 | World Cup 10 | EURO 12
    Quote: Killin' Tube Kinks One Coil At A Time
    Hackintosh Lover
    "Dumb people" shouldn't use "Smart Phones"
    New Personal Wallpapers Selection
  3. #228
    Nov 2009
    Portugal
    0
    Well i tried first to upgrade to leopard, i boot from the dvd but it just gets stuck at apple logo and a whirl twisting, it just wont load the dvd.. what migth this be?
  4. #229
    Aug 2009
    10
    Forget Leopard try Snow Leopard, or forget updating all together.. just boot the DVD from start up and try formating the HD and installing Lion...
    If it doesnt boot the Lion disc.... am not sure, it might be the DVD wasnt burned properly?... try an external DVD reader if you got one? always had problems with SuperDrives.... so I took mine off and added an extra SSD, I use an external disc drive to burn and load Dvds....
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  5. #230
    Nov 2009
    Portugal
    0
    It just wont boot the lion disc, the lion disc only show at the desktop menu and can be used by there, cant be used to boot. Im using snow leopard, it is show also at the desktop menu and at the boot menu pressing the option key but when i press osx install dvd it just loads and gets stuck at apple logo like that image, dont know if the dvd isnt well burned or if it´s just the macbook that isnt reading it properly because i dont want to waste more money at dvd´s for nothing..
  6. #231
    Aug 2009
    10
    Ok it seems to me that your SuperDrive is not reading or writing properly mate, I suggest using an external one.. or using an external HDD and loading it with the image, then connecting it throw the USB or FireWire and booting from it. I will explain how to boot the Lion installer from a USB device at boot up so you can install it easier, if you can find a spare external DVD reader for your mac.
    OK so I found a link that explain better than me how to install it throw DVD or USB
    http://lifehacker.com/5823096/how-to...or-flash-drive
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  7. #232
    Aug 2009
    10
    I Dare you to buy a Laptop that isnt Hackintasible! I double dare ya! Nowadays most laptops with the second Gen Core i5/7 come with the HD 3000 gpu allowing installation of Hackintosh much easier and effortless, so there is no excuse to go without trying it if you fancy OS X on your laptop or PC!! Of course always check http://wiki.osx86project.org/wiki/index.php/Main_Page for hardware and PC compatibility!! happy Hackintoshing!!
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  8. #233
    Xtreme Member fuzz3l's Avatar
    Jan 2010
    Germany
    0
    After i used a 2009 Macbook Pro for about 3 years, i tried to install OS X 10.7.4 on my desktop station, equiped with I7 990x, Asus R3BE, 6GB Dominator GT and a nvidia 275.
    After some problems with the drivers everything works now pretty well and damn fast. A pretty good how to you will find over at tonymacx86.com, which i used to.
    Now i have a Desktop with maybe more power than a regular Mac Pro for much less money
    Quote Originally Posted by massman
    Using a mouse to adjust BIOS settings is like driving a car with automatic transmission. Even if you break all speed records, it's still incredibly gay.
  9. #234
    Aug 2009
    10
    This is quite sad, I was just banned from TonyMacx86, for suggesting a method of installing Mountain Lion DP... someone ask me where I got it from and all I said was...
    I rather not disclose my source as to not get in trouble by the legality of how I obtained it...
    And apparently I been permanently Banned for, get this ... : Blatant Disregard of forum policies on Unreleased Software or Developer Builds.... You know what?? Tonymacx F*** YOU!!!
    SO they believe, any other way to do something is the incorrect way and, you shall be banned for suggesting it.
    Therefore I shall drop my support from http://tonymacx86.blogspot.co.uk/ as they clearly no longer share my ideology of educating people, but to commercialise their Open Source material, which is a basic copy of Chameleon re-modified for their purposes...
    People that Ask me to help them on their Hackintosh may continue to do so, but I will no longer suggest or support TonyMacX content or material....
    Good Bye Tony.... and thanks for Killing Freedom of choice, speech and education..
    Welcome back to http://www.osx86project.org/ thanks for staying true to your believes..
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  10. #235
    Jan 2009
    0
    Ive been warned in other forums too simply for admitting that i'd made my own Hackintosh, and that I didn't believe I had done anything illegal (I owned a copy of the OS). Its a subject that feels like walking on egg shells to talk about.
  11. #236
    Xtreme Member davidm71's Avatar
    Mar 2007
    0
    Got punished once...
    I can relate with getting punished from Insanelymac for asking what was a SL-C bios mod. They banned me for like a day.
    I honestly did not know what that was and can understand how forums that live on the edge of legality have
    to send out a message to their subscribers about what right and wrong behavior. I mean when your posting on someones
    forum its like walking on their property and they have every right to protect themselves legally and keep order.
    On the other hand I get how its all shades of gray. Technically running OSX on anything but Mac hardware is a
    infringement on the software user purchase agreement. People fool themselves into thinking putting on a Mac
    apple sticker on their PC makes it legal. Truth is once Apple is done with sueing all the big guys like Samsung
    they will come after Tonymac and Insanelymac and shut them down. So information is power and I would save as
    much instructions there is out there and hold on to it just in case..
    Motherboard: EVGA Classified 759
    CPU: Intel 920 D0 2.66 @ 3.8ghz
    Ram: 6gb 1600 DDR3 7-7-7-20 Corsair Dominators
    PSU: PC Power Cooling 1200 ESA
    Audio: SB X-Fi Titanium
    Video: Trifire XFX 6970
    Harddrives: WD3000HLFSx2+ OCZ 120G Vertex SSD
    Cooling: HK 3.0 - XPSC360 Rad - MCP655 pump
  12. #237
    Aug 2009
    10
    FOCK them, if I break the rules, for not providing information asked I dont expect them to banned my for not answering them back. they just assumed that I obtain the OS illegally so without questioning they just wash they hands and banned me... forget all the support I provided not to mention publicity... Oh well... cant be bother with legalities... at the end of the day, just cause I say suggest something I shouldnt be banned....
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  13. #238
    Aug 2009
    10
    Mountain Lion has came out yesterday... been busy at work Ill try it out tonight on my macbook.. also a new version of Unibeast 1.5 has been released to support Lion and M.Lion will let ya know how it works...
    http://www.tonymacx86.com/61-unibeas...-based-pc.html
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  14. #239
    Aug 2010
    perth, west oz
    13
    Has anyone had any luck installing a Hackingtos on a EVGA Sr-2 ?
    thanks for any help, guys
    Henrik
    Henrik
    A Dane Down Under
    Current systems:
    EVGA Classified SR-2
    Lian Li PC-V2120 Black, Antec 1200 PSU,
    2x X5650 (20x 190 APPROX 4.2GHZ), CPU Cooling: Noctua NH-D14
    (48gb) 6x 8Gb Kingston ECC 1333 KVR1333D3D4R9S/8GI, Boot: 8R0 SAMSUNG 830 129GB ARECA 1882IX-4GB CACHE - Scratch disk: 2x6R0 INTEL 520 120GB's, 2x IBM M1015/LSI 9240-8i, Asus GTX-580
    ASUS P5W64 WS PRO, QX-6700 (Extreme Quadcore) 2.66Ghz, 4x2GB HyberX, various hard drives and GT-7600
    Tyan S2895 K8WE 2x 285 Opteron's 8x 2gb DDR400 1x nVidia GT-8800 2x 1 TB Samsung F1 (not very nice) Chenbro SR-107 case
    Monitors: NEC 2690v2 & Dell 2405 & 2x ASUS VE246H
  15. #240
    I am Xtreme tiro_uspsss's Avatar
    Jan 2006
    bouncing between Perth & Sydney
    41
    Quote Originally Posted by tived View Post
    Henrik
    yeah the is a fellow around here who had it running..
    edit: this guy here - http://www.xtremesystems.org/forums/...=1#post4476928
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    the yummy FOOD
    thread
    heatware / ebay
  16. #241
    Aug 2009
    10
    Have you tried Unibeast?
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  17. #242
    Jan 2006
    41
    hey David, seen/heard of anyone running a hackintosh on one of those new s1155 mobos with thunderbolt fully working?
    the yummy FOOD
    thread
    heatware / ebay
  18. #243
    Aug 2009
    10
    If my memory serves me right... I believe they are people running s1155.. Not sure about thunderbolt though... I'll let ya know later
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  19. #244
    Aug 2009
    10
    So far this is the only Mobo that I found, which has Thunderbolt working to some state...
    Source:
    http://www.tonymacx86.com/73-gigabyt...ices-os-x.html
    http://www.gigabyte.com/products/pro...px?pid=4279#ov
    More news when found...
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  20. The Following User Says Thank You to davidkozat For This Useful Post:
  21. #245
    Jan 2006
    41
    Source:
    you lil ripper!
    the yummy FOOD
    thread
    heatware / ebay
  22. #246
    Aug 2009
    10
    Much Obliged, a good thing to point out is, that because Intel has not pass certification to a lot of Asus and MSI mobos with Thunderbolt externally, its my guess that the amount of Mobos with Internal thunderbolt would probably increase...
    Source:
    http://www.tonymacx86.com/86-asus-th...ification.html
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  23. #247
    Jan 2006
    41
    Source:
    sooo.. you can't plug in a discrete GPU? that's all? if that is all, meh, don't care!
    I'm guessing Intel is being losers by charging heaps for certification.
    wait.. so they aren't certified but does that rule out 100% function? :/
    the yummy FOOD
    thread
    heatware / ebay
  24. #248
    Aug 2009
    10
    Ok just to clarify: Well the Non Certified Thunderbolts are the those used in many (Not All) Asus and Asrock as they use external ports for their discrete graphics .... = Not support, No Display... Why?:
    The issue is that Asus' Thunderbolt card and ASRock's Thunderbolt motherboard uses an external cable to connect a discrete graphics cards DisplayPort connector via an input connector on either the card or the motherboard which connects the display signal from the graphics card to the Thunderbolt chip. This is not something Intel is at least currently allowing for and as such the two companies were turned down for certification.
    For the Gigabyte Mobos using the Intel DSL3510L chip:
    The thing so far. is that you can’t hot-swap Thunderbolt devices using the Gigabyte boards and this simply because they’re not detected as being a Thunderbolt device, but are instead seen by the OS as an internal PCI Express device. Since Thunderbolt is pretty much an external PCI Express interface, this makes sense. What this means is that you have to plug in your Thunderbolt devices at boot, which might not be ideal for everyone, but it’s something that we’re hoping to be able to solve given enough time. Note that things like hard drive docking solutions where you have a removable drive are still hot swappable on the drive end, as long as the dock itself supports hot swappable drives.
    Further more am Not sure about, Asus, MSI or Intel motherboards with the single port DSL3310 Thunderbolt controller that have tried to attach a Thunderbolt device, as currently I don’t know if the DSL3310 Thunderbolt controller is compatible with OS X or not and it would be good to have some confirmations as to whether or not it works. So far we’ve only had a single report about the Apple Thunderbolt display in the forums, but it’s not conclusive, although a user going by the name of Einsteiniac claims to have gotten his display working, albeit not entirely flawlessly, as the display turns off before you reach the OS and as such he had to unplug the display and plug it back in to make it work.
    Final Comment:
    Intel is currently the sole manufacturer and certifier of Thunderbolt controllers and as such, if you don’t meet or exceed Intel’s specification, then you won’t get certified and in turn, your product can’t carry the Thunderbolt logo. In this case it appears to be more of a political issue than an actual concern about Asus and ASRock not meeting Intel’s standard, as Intel is clearly using Thunderbolt as a means of pushing its integrated graphics solution.
    This is at least so far bad news for CustoMac users, as either solution would’ve made it much simpler to use a discrete graphics card with the Thunderbolt/mini DisplayPort connectors on the motherboards. It will be interesting to see if the two companies can make some kind of deal with Intel to allow this implementation in the future, or if they’ll simply ignore the certification process and still sell their products, although the latter option doesn’t seem all that likely.
    So if you would like to use 2 Thunderbolt ports, for Display + Devices I suggest buying a Mobo with Intel chip DSL3510L, which is of course certified, and the best supported under Lion and Mountain Lion.
    PS sorry for the Long Post.... LOL
    Sources:
    http://www.tonymacx86.com/hardware-n...tml#post386706
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  25. The Following User Says Thank You to davidkozat For This Useful Post:
  26. #249
    Aug 2009
    10
    Got bored at work so decided to install Mountain Lion on my Work laptop.. Dell Latitude E6320.. working and performing surprisingly well!.. Next installing it on a Raid 0 of 2 SSDs Sata3 lets see how quick it loads...
    http://img708.imageshack.us/img708/2...9172417260.jpg
    OLD RIG
    HAF 932 Modded Case
    MB: Asus P6X58D-E
    Hackintosh Lover
  27. #250
    Jan 2006
    41
    Attachment 129154
    is that using that unibeast(?) method you use?
    the yummy FOOD
    thread
    heatware / ebay
+ Reply to Thread
