Definitely Nickel Flake.
My memory might be bad, but I'm pretty sure reference PCBs are identical. Wasn't the 9800 GTX very quickly replaced by the + because the normal one couldn't keep up with the 4850?
The G92 cards often share PCB layouts, the 8800 GT and GTS have exactly the same layout (I got a GT block on the GTS).
+1 on this.
Newer GTX+ arnt reference ... be awere !
- Le Quebecois -
- - - BTTB - - -
EVGA X79 FTW - I7 3820 - PH-TC14PE - 16gb G.Skill 2133mhz - EVGA GTX 670 + Accelero TTII
Tecnofront HWD BenchTable - Antec TPQ-1200-OC - 2x Agility 4 256gb - Surround Asus VE278Q 5760x1080
- - - HTPC - - -
Asus Z77-m Pro - 2500K - NH-C12P - 2x4gb G.Skill Ares 1600mhz
Asus GTX 650 TI - X25-M 80gb - Enermax Naxn 550w - Lian Li PC-C60B
- - - NAS/Server - - -
Gigabyte H77m-D3H - G2020 - 2x4gb G.Skill 1600mhz - 2x 1TB Black - 1x 2TB green - CX430M
Forum Quebecois, si tu parles francais !
Differance for reference design 9800 cards is only 65 to 55nm gtx/gtx+
http://www.dvhardware.net/article28059.html
i have Asus 9800GTX+ With full coverage EkWaterblock 9800GTX
yes i know bad image quality but i have no other picture in this moment...
http://img7.abload.de/img/dsc04111x5cx.jpg
- You may not post replies
- You may not edit your posts
Forum Rules
