Hello,
Market seems to be flooded with non-reference 5770's, but since im planning to go water I need a reference 5770 which will be compatible with this EK water block. Also wanted voltage control out of the box, hence was looking for the MSI and ASUS 5770's with the reference design but they are out of stock everywhere, and they have been replaced with crappy non-reference ones. Now I know there are a few reference sapphire 5770's, but even those are becoming rare. XFX seems to be sticking to the reference design im if not miskaken. Also, all V1 and V2 coolers should be based on the reference design?
Theres also this version of sapphire, and im not sure if its a reference design. I also hear about V3 versions not supporting voltage control. Wtf is V3? V1 to V2 only changed the cooler, ive never heard of V3. Is V3 just non-reference? Zzz
Basically, I need a 5770 which has a reference design and hence would fit the EK water block and can also be flashed to a msi/asus bios for voltage tweaking. I guess its the safest sticking to the V1 and V2 coolers from any manufacturer, since im guaranteed to get the reference design?
