Results 1 to 14 of 14
Thread: RAID without format?
    May 2010
    Hello
    I allready have everything installed on my 1 HDD. Had it on for 6 months.
    If I buy anther same HDD, is it possible to RAID them without formating?
    Which Raid can I make?
    EVGA E760 Classified
    i7 920
    Xtreme Cruncher
    Dec 2008
    The Netherlands
    Depends on what raid you want to use. You can use Intel Rapid Storage Manager to create a raid1 set (mirror), but it won't be possible to make a raid0 array (stripe for size/performance) without formatting.
    May 2010
    Ok how do I make a RAID1?
    Can you show me? explain?
    Xtreme Cruncher
    Dec 2008
    The Netherlands
    Download and install Intel Rapid Storage Manager. It has easy-to-follow guides build in program to help you configure your raid array.
    Download link: http://downloadcenter.intel.com/Deta...=2101&lang=eng
    Mar 2008
    Why do you want to run raid? Do you know what the different RAID levels do?
    Xtreme Cruncher
    Dec 2008
    The Netherlands
    Quote Originally Posted by Oats View Post
    I too am having a feeling he doesn't really know what he will achieve by going raid1. I think he wants extra space and performance, and for that, he's have to go with raid0, but it will require a format.
    @OP: You do realize raid1 won't give you any extra performance or space, right? Raid1 is to protect your data against drive failure. It stores all your data on both drives, so that if one of them fails, you will still have your data, because it was mirrored to the other drive.
    Feb 2009
    Fremont N.H. USA
    If you plan on putting important files or documents on your computer I would highly not recommend raid 0. Raid 1 is much better in case of drive failure.
    Xigmatek Elysium Case
    Intel I7-3770K
    Asus Sabertooth Z77
    16 Gigs Ripjaws 2133mhz Ram
    Mushkin 240 SSD
    Lightscribe Dvd Burners
    EVGA GTX 680
    Aquacomputer Gpu Block
    Cooler Master Hybrid 1050 Watt Pws
    EK Supremacy Cpu Block
    Xspc RX360 Rad
    Xspc XS360 Rad
    Phobya 250 Balancer Res
    2 x Mcp 350 Pumps
    Oct 2007
    US
    fuk Intel Rapid Storage Manager :S
    Intel core i7 980x
    6GB mushkim
    ASUS Rampage 3 Extreme
    EVGA GTX 580 SLi
    LG L246WP Widescreen
    Auzen X-Fi HomeTheater HD
    Corsair HX1000w
    WD Velociraptor 600GB Raid 0 l WD 1TB Black l Intel X25-M 80GB G2
    Silverstone TJ07
    OCGuate!
    Uber Raid King
    Aug 2009
    Wichita, Ks
    why?
    "Lurking" Since 1977
    Jesus Saves, God Backs-Up
    *I come to the news section to ban people, not read complaints.*-[XC]Gomeler
    Don't believe Squish, his hardware does control him!
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by rmorse27 View Post
    raid0 will not make things all that more likely to die from hardware, ive used raid0 for a long time almost a decade and the only drive that ive had died had problems with dropping from the array for months before a failure. what could have problems is file corruption and thats why u need to keep important files in separate locations.
    Quote Originally Posted by Marvin54 View Post
    why, it dose nothing but help without it you could not change controller settings or get warnings of strange drive behavior
    5930k, R5E, samsung 8GBx4 d-die, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB , CM690II, swiftech h220, corsair 750hxi
    May 2010
    I changed my mind, I will format and go for RAID 0.
    Can you guys help me do it?
    I have 2 HDD Satas 160x2 320 total.
    WD and Seagate.
    I dont know how to do it. Please give me a fast guide
    Jul 2007
    SF bay area, CA
    dont raid those, those drives are old so they will have a good chance of failure. then u should not do dissimilar drives. go spend $55 on a 500GB f3 and it will be multiple times faster than your setup even if u raided those.
    May 2010
    They aren't old in usage. They are used for 4 months, 1 of them is brand new. If I understand?
    Jul 2007
    SF bay area, CA
    they are old as in slow and on low density platters, there are also a bunch of different platter configs with 160GB drives. you have slow dissimilar drives dont use raid just go buy a faster drive like the f3 as i mentioned if u want faster
