Hi, I'm going to buy a new cpu cooler.
Which one do you suggest between Prolimatech Armageddon and AlpenFohn Matterhorn ?
I think that the armageddon is better , but I'm not pretty sure.
Theres just isn't enough trustworthy material about the Matterhorn around the nets. Armagheddon otoh is quite mediocre coming a couple of degrees short on Megahalems. If you don't want something the size of a Noctua NH-D14 the Venomous X is the next best thing.
Must agree the megahalems/venomousx will do you fine. The nh d14 has the edge but is just too damn big and the Armageddon falls short of its bigger brther megahalems.
EVGA X58 Classified
Intel Core i7 980X @ 4ghz
EVGA 590 GTX x2 Quad SLI
Corsair Dominator DDR3 12GB PC3-12800C8
Western Digital 150 GB Velociraptor
Corsair AX1200
Asus Xonar Xense
Custom Watercooling
Lian Li Pc-P80 Armoursuit
I don't really like megahalems' and venomous' design..
I've choosen the armageddon cuz it leaves some space for tall ram modules and I also like how it looks.
Reading some reviews I've seen that it performs really close to the megahalems, just 1 or 2 degrees worse
Of these 2 HSFs, Matterhorn gets my vote although its performance is still unknown
Armageddon seriously has compatibility issue with some mainboards out there
Intel Core i7-930 | High-End Water Cooler | Asus P6T6 WS Revolution | G.Skill Ripjaws X DDR3-1600 6-8-6-24 1.50V 2 x 2GB | Sea Sonic SS-750-JS
Then you're lucky there is a list of incompatible mainboards on Prolimatech page, you may want to check it out
http://www.prolimatech.com/products/...rmageddon.html
