+ Reply to Thread
Results 1 to 11 of 11
Thread: mobo,cpu , gpu in one loop?
    Xtreme Member LLiH's Avatar
    May 2010
    4
    Lightbulb mobo,cpu , gpu in one loop?
    Hello
    If I have a D5 pump, and an XSPC RX 120mm x 3 radiator, will it cool my hardware in one loop? (Sharkoon 2000 golf ball fans)
    EVGA E760 Classified
    Rad
    Mobo wblock (EK)
    cpu wblock (Swiftech)
    5870 wblock (Swiftech)
    Res
    Pump
    Jun 2007
    mars
    0
    ball fans are good things, but how do you plan to regulate fan speed?
    Intel Xeon W3520 4200MHz HT
    Foxconn Bloodrage
    3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
    MSI GTX480 M2D15 850/1700/2000
    Samsung F1 1TB
    Corsair TX950W
    Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
    NEC 2690WUXi
    Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
    Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
    *New* CM 690 II Advanced Watercooled
    *Coming soon* Stacker 832 Rebirth!
    May 2010
    4
    Hi rioja
    I use a fan controller.
    Xtreme Enthusiast Gimmpy224's Avatar
    Sep 2005
    DFW
    6
    i7 im assuming? And OC'ing comes into effect aswell.
    Quote Originally Posted by freecableguy
    I'll come blow on your heatsink for a dollar. Thats pretty ghetto
    Quote Originally Posted by Xeon th MG Pony
    sorry to sound harsh but so would you if some one asked if nitroglycerin was a good coolant for his car!
    May 2010
    4
    Yes i7, with overclock.
    Im at 4Ghz stable now.
    Will it work with all this in 1 loop?
    The GPU is also overclocked a little bit.
    Xtreme Member Devil_Dog's Avatar
    Dec 2008
    Jersey
    5
    I wouldn't run a single loop with all of that on a single 120.3.
    I am Xtreme lowfat's Avatar
    Oct 2005
    Grande Prairie, AB, CAN
    15
    Of course it will work. Don't expect crazy overclocks out of the CPU though. But 4GHz will be simple enough.
    Xtreme Addict ScottALot's Avatar
    Feb 2010
    Wisconsin
    2
    If he took the mobo out of the equation, would CPU clocks be a little less restricted? (significantly?)
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Oct 2005
    15
    Quote Originally Posted by ScottALot View Post
    Well I am no pro when it comes to flow () but I don't think so. The heatdump from the videocard just might slighly lower how high he can clock the CPU. Either way if he is just reaching for 4GHz, it shouldn't be a problem.
    May 2010
    4
    So just to refresh this thread,
    The loop will contain the following hardware:
    Mobo N/S + Voltage reg
    CPU overclocked i7 920 4Ghz
    Hd5870 Small overclock
    1 RX 120x3 XSPC Rad
    D5 pump
    5:25 res
    Xtreme Mentor Jamesrt2004's Avatar
    Feb 2007
    Oxford, England
    6
    will be fine just dont expect too great temps
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
+ Reply to Thread
