+ Reply to Thread
Results 1 to 7 of 7
Thread: Same 930 chip, Gflops different on stability compared to other 930's.
    Feb 2009
    England
    0
    Hi all
    I have been stability testing alot and have noticed that the same 930 chips give a different Gflops reading in Intel burn test and Linx,sometimes it 35 or 45 or 55 or 65...why is this?Are some of the chips faulty?
    Case:Antec 1200
    PSU:Corsair AX 1200w
    Motherboard:Rampage Extreme 2 x58 on Water
    CPU:I7 930 @4.4ghz HT on (1.43) 24/7 on Water
    Radiator:Swiftech Mcr 320 QP Triple(using Radbox)
    Block:Swiftech Apogee XT/ EK-FB RE2 ver.2 Acetal+Nickel/EK-Mosfet Copper Plexi
    Reservoir:Swiftech Micro Res v2
    Tubing:Primochill Blue
    Water: Deionzed with PT Nuke
    Memory:6GB Corsair xms 1600mhz(1675) 9-9-9-24-2N
    Hardrive:300Gb Raptor-500GB Wd-1TB Wd
    Sound:Asus Xonar Xense
    Headset:Sennheiser 350
    GPU:Gigabyte GTX 690
    GPU Driver:313.95
    3D Vantage:51283
    OS:Windows 7 Ultimate
    Mouse:Logitech G500
    Keyboard:Logitech G11
    Mouse mat:Razer Destructor
    Monitorell U2410 rev5 24inch 16:10
    Fully Stable: Linx Occt IBT Prime 95
    May 2005
    0
    It's a stability test, not a benchmark.
    i5 750 @ 4.2ghz
    EVGA P55 FTW
    8gig G.Skill Ripjaw @ 1055mhz
    Gigabyte 6950 modded
    Seasonic X-650
    Antec P180 modded and watercooled
    Thermochill PA160
    Apogee XT
    MCP350
    Xtreme Member Anth Seebel's Avatar
    May 2004
    somewhere called australia
    0
    gflops will indicate if your loading the cpu properly (stable settings).. if gflops are low the cpu is not actually loading properly at that clock , that is why gflops are low..
    i have tested this extensively..
    i am able to get higher clocks but gflops can be low which indicates to me that cpu is not properly loading - so il stop linx and adjust settings.. i can observe this with temps (along with low gflops).. a properly loading cpu will have a higher temp..
    3770K @ 4.8 HT (EK HF)
    ASUS P8Z77V PRO (1708)
    Trident X F3-2400C10D-8GTX
    GTX 480 SLI / E-MU 1212M / Antec Quattro 1.2kW / HP ZR30w / Lian Li 1010B
    Cooling; CPU - EK Supreme HF Full Nickel EN / GPU - 2x Koolance NX-480 / TFC Xchanger 240 & RX360
    655 w/EK-Top V2 / Tygon / BP Compressions / SS Kayl 1/3hp
    Feb 2009
    England
    0
    thankyou for the explanation
    Case:Antec 1200
    GPU Driver:313.95
    3D Vantage:51283
    Mouse:Logitech G500
    Feb 2009
    England
    0
    Quote Originally Posted by Anth Seebel View Post
    How do i make the gpu load at he proper settings?
    My theory is you cant unless you downclock?
    Case:Antec 1200
    GPU Driver:313.95
    3D Vantage:51283
    Mouse:Logitech G500
    Xtreme Mentor CryptiK's Avatar
    Aug 2008
    Australia
    6
    Sometimes just stopping and restarting the test works for me.
    Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
    Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
    Xtreme Addict OC Nub's Avatar
    Dec 2007
    16
    Quote Originally Posted by CryptiK View Post
    Same for me, LinX is not a perfect program.
    I can pass 25 loops LinX and still fail the latest version of p95 running blend in less than 1hr. IMO LinX is not the end all to stability testing.
+ Reply to Thread
