Where do you buy those quality caps Napalm?
Intel Core i9-7980XE@ 4.8GHz 18C/18TH (Direct Die Contact)
ASRock X299 OC Formula
ADATA XPG SPECTRIX D80 (4x8GB) DDR4-3800C17 B-Die
1x Intel Optane SSD 905P 480GB
4x HP EX950 NVMe 2TB on ASRock ULTRA M.2 CARD
EVGA RTX 2080TI KINGPIN 2190/8000 Stock Cooling AIO 240
SilverStone ST1500W-TI TITANIUM
Alphacool Custom Water Cooling
Hey Jor i see Brazil cups there you have a great team how you make it
Those are solid caps i can find here also much easier to buy rubycon electrolitics...
Im sure you can get them on a good electronic store.
here's a link (napalm plz confirm) this are very low ESR
http://cgi.ebay.com/40PCS-470uF-16V-...item5192c10582
Cheers
Sergio
pepinorang - nice
sergio - those caps @ ebay are good
jor - i got the 470uf chemicon caps
digikey.com -> search "capacitors" -> click "aluminum" -> filter voltage "16v" -> filter esr "9.0/10.0/11.0 mohm"
and you get..
16v 470uf 9mohm: http://search.digikey.com/scripts/Dk...me=493-3019-ND
16v 470uf 10mohm: http://search.digikey.com/scripts/Dk...me=565-3234-ND these are the ones i use
16v 820uf 11mohm: http://search.digikey.com/scripts/Dk...me=493-3115-ND these are the ones pepinorang uses
cant go wrong with any of these caps
if you got the cooling you can also go with the 2200uf or 2x 2200uf if you got enough space
you can also go with film capacitors..
i tried these 5 mohm cornell 940c: http://search.digikey.com/scripts/Dk...me=338-1170-ND
theyre big but these would be ideal to keep gtx480 warm @ subzero temps
go brazil!!
I have 16x 4700uf 16v caps on the way for 2x SSC FTW 480's...just completed OCP and CBB, still need to do OCP for vMEM and throw on the VR's....caps will be here in another 4x biz days
Sure didnt.. :o ..but can though, and my supplier has up to 8200uf @ 16v as well...gonna see how these 4700's do first though. Pics to come soon as more substantial work gets done here..supposed to be in Pebble Beach atm, covering the 'Open' for ATT mobility..snafu's in the way atm though!
3-0
Nice Uruguay
A friend sent me some capacitors . They are exactly these from FRAKO . 16v/1000μF
I submerged them to LN2 and at -80c i measured 700μF capacity . At -70c around 850μF ... And -60c almost 1000μF .
Below -80C they loose pretty fast their capacity , but this will never happen because they are far away from the cold gpu core .
Do you think i should use them ??? I have a friend who can test their ESR ...
those caps look great..especially with the temp tests you quoted Look like the right stuff to me! ..and you got just enough for 1x GPU.
*from what I understand, ESR is not an issue with the 4xx's.. only capacitance..so uf rating would be more important than given ESR value of the cap, for the mods you are doing.
@NapalmV5, is there similar pencil vmem mod for GTX480 like this one for 470:
http://http://vr-zone.com/articles/nvidia-geforce-gtx-470-voltage-modifications/8763-3.html
|RIIIE||Xeon W3520#3845A935|EVGA GTX480||PC3 16000 Kingston HyperX 6GB||2x150GB WD VRaptor||WD6401AALS||HAF 932//CM 1250W||LenovoL220x||X-Fi Xtreme Music||Lycosa+Lachesis+Destructor+G27+P880|
WC-Loop1: CPU |EK-Supreme HF|Magicool Xtreme III||MCP355||MCRES| Loop2: VGA/NB| EK-FC480 GTX-Acetal / MCW30|MCP655|MCR220QP|MCRES|
if im reading your post correctly, you have just increase the memory of the card with your mod?
Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
If I understand the goal to add capas on VGPU, I don't understand the serial connection... It decrease the global capa and increase the ESR/ESL. So it's at the opposite of voltage regulation. So, do I miss something ?
Been awhile since I've been in school so correct me if I'm wrong, I always thought that capacitors work the opposite way as resistors, in series resistors value are added and in parallel they are divided, so when you put capacitor in series, the capacitance should decrease, so in theory it would be better to use them in parallel for double cap?
EVGA P55 Classified
i7 860 (today)
Perfect Storm 2133
3X 5870
Megahalem with 1 delta 220cfms
Navig bench station
There are already 1x set of caps on board..so adding 2x more sets linked in series, you have 3x total now..
*series = increase in voltage potential
*parallel = increase in current potential
If you think of them as battery's..
stock = 12v of electrical potential on the input phase
1x set of caps in parallel = 12v, with increased current potential on each input phase
1x set of caps in series = 24v of electrical potential on the input phase
2x set of caps in parallel = 12v, with increased current potential on each input phase
2x set of caps in series = 36v of electrical potential on the input phase
..granted the GPU is still being fed from a 12v source..but you get the principle.. 'extending the capacitance'
Very Nice thread!
Thanks Napalm and others for sharing!
http://farside.ph.utexas.edu/teachin...es/node46.html
if you have a 12v source across two capacitors in series the voltage across the two capacitors will be the same.
when computing for total series equivalent capacitance..well you use the capacitance formula 1/Ceq = 1/c1 + 1/c2 + 1/ce ...
there are minimal uses for series capacitance in the first place because of loss of "capacitance" or should i say lesser capacitance unless its really needed - read http://www.coilgun.info/theorycapaci...apacitors2.htm
