Is there any led 1920*1200 monitors you know?
When i'm being paid i always do my job through.
i think that apple has some, but led dosnt make a difference under 37"
3770k, M5E, kingston 2x4GB cfr
samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
DFI UT X58-T3eH8 bios 08/09/10 * i7 920 d0 batch 3847A 4Ghz@1v * Kingstone HyperX 3x2GB 1866Mhz * 26" Hazro HZ26WSi * ATI FirePRO 3D V4800 * Corsair TX650W * WD Caviar Black 1TB * LG BH08LS20 * MS Sidewinder X8/X6 * Audio Technica ATH-AD700 * Slackware 13.64/windows 7.x64. WC: Enzotech Sapphire,Swiftech MCW-30,Thermochill PA120.3,XSPC Dual Res.Pump. FOTO * Dell Precision M4400
They would, yes, and there is also such a thing as "too bright"![]()
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
Windows 7 + SSD:
Mode: AHCI, default Microsoft driver or latest Intel RST
Defrag: Off
Hibernation: Off (use Sleep mode, recommend a UPS)
Indexing: On (it only indexes a few locations, not your whole system unless you tell it to)
Page File: On (set to the minimum of 16MB if you have a large amount of RAM, disabling not recommended)
Prefetch: On
Superfetch: On (RAM is always faster than an SSD - use it)
System Restore: Off (with regular backups)
Browser Cache: RAM Only, Disk Cache Off (How to with Chrome)
Documents, Music, Pictures, Videos, Downloads to HDD (Public Libraries too, see above link about junctions)
UAC: On!
The ability to go to bright is a good thing though, my work monitor used to be bright at 60% but now it's painfully dull at anything below 85% and I normally leave it at 100%.
idealy u want to have brightness and back light independent since lcds have the best color at max brightness but then if that also ups the backlight then its to bright
16:9 is a standard, why would you want anything else?
Because 16:10 is also a standard, and shows more content? Given the option, why would you want less?
I'm puzzled by this move towards monitors with less vertical height lately. Sure it ties in well with all the "full HD" marketing blitz, but a PC monitor is designed for the consumption of very different media than a TV. On a TV you purely consume movies, which are naturally wider then they are tall. On a computer you consume word documents, e-mails and websites, all of which are naturally taller than they are wide.
Rig specs
CPU: i7 950 @ 4.2GHz Mobo: eVGA Classified 760 RAM: 3x2GB Corsair DDR3-2,000 Dominator GTs @ 2,000, 8-9-7-24
VGA: Crossfire Sapphire HD6970s SSD: OCZ Vertex 2 60GB HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520
SFX: Auzentech X-Fi Forte w. OP637AU PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 Pro x64
Liquid-cooled
-=- EK-Supreme HF -=- EK Classified FC -=- 2x MCR120 + MCR320, Scythe Gentle Typhoon 1850s -=-
2x MCP355 w. XSPC Dual-DDC Top -=- EK-Spin bay res -=- 7/16" black Pro-LRT w BP compressions -=- Aquaero w. Powerbooster
Peripherals
-=- 3x Dell U2311H (Eyefinity) -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
Foundational Falsehoods of Creationism
Pretty good article related to your comment, though might be already common knowledge to the average person here:
http://www.maximumpc.com/article/fea...yths_shattered
Prodigy Yang i5 3570K | Asrock Z77-E ITX | 8GB Samsung 30nm | 7950 TF3 | 240GB OCZ Agility 3 RAID 0 Apogee HD White | NexXxos 120 | XSPC X20 750 Pump/Res ![]()
It's sort of how like 6" is standard, 8" is better![]()
I don't care about standards. For me 16:9 is useless and claustrophobic.![]()
Due to profits plain and simple.
19" 4:3
22" 16:10
24" 16:9
19" die has been paid for many times over and when rolling out the panels just cut the same TFT panel 3" longer and 5" longer.
This costs alot less than making a larger die and should cut down on bad panels since the 19" die has been tweeted for many years.
This is speculation only but I think it makes sense. I bought a Dell 24" widescreen to replace my son's 19" and the only thing different was width. As stated before the documents are no taller than the old 19"
i7 920 @4.305 ghz (205*21 HT on) Prime stable@ 1.312v (Batch# 3844A717) your results may vary
XSPC RayStorm (very nice block)
GA-EX58-UD4P (Bios ????),, 6GB- OCZ3P1600LV6GK (7-7-7-20 @1640 mhz) 1:1
XFX-5870 with Swiftech Komodo nickel block
Water Cooling - MO-RA3 Pro with 4 Silverstone 180mm @ 800 rpm, Twin Vario mcp-655 pumps
Samsung 830-512 SSD,, OCZ ZX-1250W (powerfull and silent)
Dell U2410 decent monitor for IPS too bad SED tech died![]()
Docsis2.0
Docsis3.0
http://www.xtremesystems.org/forums/...28#post5044028 could save you 30-50% on dental costs.
-- People who reject the idea that "government has a responsibility to reduce income inequality" give an average of four times more than people who accept that proposition.
Rig specs
Liquid-cooled
Peripherals
manufactures can also profit from designing cheaper panel due to larger dot pitch.
24" screen 16:9 vs 16:10
24"(1600:900) = 20.92" wide by 11.76" thus 11.76" * 25.4mm/inch / 900 = dot pitch of .332mm
24"(1600:1000) = 20.35" wide by 12.71" thus 12.71" * 25.4mm/inch /1000= dot pitch of .322mm
now for a good monitor
24" (1900:1200) = 20.289" wide by 12.82" thus 12.82" * 25.4mm/inch /1200= dot pitch of .271mm
The 1900 x 1200 monitor has nearly the same ratio as the 16:10 but with a much smaller dot pitch.
Its dumbing down marketing to make more profits.
another example a Dell U2711 has a dot pitch of .233 mm and costs over $1,000
Docsis2.0
Docsis3.0
Are you confusing ratio with resolution?
16:9 ratio 1920 x 1080 Acer P235Hbmid dot pitch is .265"
Are you confusing ratio with resolution? -- same thing see below
lets go backwards on your monitor selection
1920 * .265 = 20.0314"
1080 * .265 = 11.267"
16/9 = 1.77777 ratio right ????
20.0314 / 11.267 = 1.7777 hummm interesting????? no?????
(20.0314*20.0314) + (11.267*11.267) = 528.2 sqrt = 22.982" dia or 23" as the model # states P23
so working backwards the ratio is 16:9 and the dia = 23" and the "resolution" of 1920 x 1080 with .265mm dot pitch works out perfectly.
Gotta love Math it just works so well
_____
off topic Pagan2 you should like this http://www.youtube.com/watch?v=hcR7hr4LLQg
Docsis2.0
Docsis3.0
