I have my second pc using a Core 2 Quad Q8400, cooled with a corsair h50, all stock speeds.
In HWmonitor, both core 3 and 4 are stuck at 37c and 39c respectively. These temperatures never ever change, even when the temperatures on cores 1 and 2 fluctuate. (They idle around 25-30c depending on room temperature)
I've tried reseating the pump at least 5 times with no effect to speak of, and the CPU is in no way warped, nor is the mounting improperly seated.
Is this some sort of software bug? I've tried multiple temp programs, and all have the same problem.
