My GA-P35-DQ6 just passed from it's malfunction to being non-operational.
The rig is (or was):
Gigabyte GA-P35-DQ6 (Rev 1.0 BIOS F9)
4GB GSKill DDR2 1066 5-5-5-15 2T running @984MHz & 2.00V vdmimm
C2D E6750 @3.28GHz (8.0 x 410).
No overvolting of any sort. Keep the DRAM running under 1000MHz, so I need just 2.00V or less. CPU can go up to 3.36 without any additional Vcore, just kept it at 3.28GHz to give some "free room".
PSU: Corsair 650TX
I'm seeking advice as I need a replacement motherboard. I just don't know what to pick. Avaiablity of LGA775 boards aren't the greatest these days. I'm also very outdated on what would be best suited for my needs and what I should keep away from. I see a lot of G41M boards. I would like to keep at least the kind of overclock I had.
The problem: system was starting to load Windows, then a hard freeze happened. Power and HDD leds lit. Had to force shutdown via PWR button. When I attempted to power on again the fans are spinning and leds are lit, but there is not POST, no beep, no display, and the Power and HDD leds stay lit.
I tried to Clear CMOS, then it only got worst. It powers on and then starts cycling on and off, like 3 times, then it power on and keeps frozen. Also no POST/beep/display.
I've tried the CPU, video card, ram modules and PSU on another computer, and they work. Tried different CPU, video card, ram and PSU on my GA-P35-DQ6 and it does not start.
One thing curious is that I have a spare pair of Crucial Ballistix Tracer with those shiny leds, and when the PC powers on the leds from the top part of the Tracers won't lit. They usually do lit and blink when the system is at POST.
My rig is not new, it's from August 2007. Started to show some issues sometimes:
It would cycle one time on/off than lose all overclock settings.
FAIL to post - hard to turn off PSU, start again
Start and give no display image at windows startup.
Resetting PCI-Express speed to x1 instead of keeping x16.
Freezing during games or at Windows
The 8800GT isn't looking any good either. Sometimes it's not detected (1 long beep and 3 short beeps). Not only on this computer. When the card does not want to work, it doesn't work. It needs a little "sleep" then works
I think the BIOS of my board might have gone bad. The chip is soldered to PCB, and I doubt I'll have anyone to have a look or fix it. RMA is not really an option: actually I bought this board in Germany, it has 6 years warranty with Gigabyte DE, but the costs and time to have it shipped out and back, plus taxes will probably make RMA not a good option.
Thank you all!
