Some new pictures that Acar send on Ocfroum.pl:
Blue/White doesn't look bad.
Black/Orange looks good.
What gauge wire are they actually using?
My toys:
Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
They Use: H05VV-F 3G 1, 5mm2 wire
Functionality-wise these cables won't do a thing more for you than the free cable included with your PSU, but HOT DAMN they look good
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
What about those people who spends a few hundred Gs on their systems? Spending a couple hundred bucks on the cables won't be justified for them, hell, they think that they should spend a little more to balance the costs out...
Some people will just have too many money to spare, maybe it does make a difference, but maybe they don't. But let's put these stuffs aside, after all, it is their money and we are not their accountants
It is just a matter of psychology. Given to you, let's say, 6 MC1201s for a home theater, would you feel justified spending just a couple hundred dollars on the speaker cables?
You mean MC1.2KW's?
Probably not a couple hundred on wires. I'd probably buy some #10 AWG copper biwire and spend a few dollars on spades and/or banana connectors.
It just annoys me when people insist that your wires should cost as much as your car is worth. You'd be better off spending money on better loudspeakers. They almost always induce much more harmonic distortion than sources, cables, power, and ontrol... combined.
My toys:
