I just got installed and I'm getting this error -
scheduler request failed . Peer certificate cannot be authenticated with known CA certificates
what to do.
what to do.
If you're running a linux distribution, they left out a certificate in the BOINC download. I wrote a how-to on it at poppageeks website. http://www.poppageek.com/howtos First howto, starts at step 4 to download and install the certificate. If its not a linux distribution, then I'm not sure.
I downloaded this software
Windows ®
(6.2.28)
(Vista, XP, Me, 2000)
md5: e99bbe9ab88f91cf38d21f66b9441f32
What OS Ron?
Got an Xtreme System? Bring it here! <----
Whichever OS it is, I suspect the cause is similar. WCG apparently is the only BOINC project which requires a secure connection to the scheduling servers, so if they forget to package the certificate with the BOINC download, it's not going to connect properly. Apperently not having the time set right will do it too. Here's a link I found regarding the error http://bolt.berkeley.edu/trac/wiki/E...quest%20failed
Win XP
LOL - clock is definitely not right. I'll give that a try.
Hope it works! Glad to have you on board
WOW - as soon as I changed time and date , the download started.
thanks buddy
No problem, thank you for crunching!
OMGoodness - I'm crunching
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
So runmc, What time is it?
My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
Hey Ron, Great to have you on board!
Heatware | Ebay:Crazymullen | If you are unsure what Fhqwhgads means You are REQUIRED to go HERE| Powered by Centon Ram
IMHO Waste is a computer going to a landfill having done actual computations less than 90% of it's life. 90% of the computers powered on right now are idle or powered off; what a waste! [/B]
Is it a coincidence that your wifes pc is called Uranus?
Welcome aboard.
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
Have fun.
You run under "that other guys, team admin" right?
Good to have you on board 100% as you!
Texas is represented now! Crunch On buddy
For those that don't know Ron is the guy that brought me here back in November 2005..
Also one of the nicer people you will ever meet.
I have a 9800gtx on my chruncher. Can I make use of it?
