hmmmm it doesnt really look better than the stock heatsink, does it?
i mean not stylish but as in not looking more powerful and efficient and silent...
damn it guyz show some love
SHOW IT :shakes fist:
Main Rig
- Intel Core i7 4790K CPU Stock @ 4.4Ghz
- Asus Maximus VI Extreme Motherboard
- 32GB GSKILL Trident X 2400MHZ RAM
- EVGA GTX 980 Superclocked 4GB GDDR5
- Corsair TX850W v2 TX Power Supply 70A 12V Rail
- Swiftech Apex Ultima w/ Apogee Drive II & Dual 120 RAD w/integrated res
- 2X Seagate 333AS 1TB 7,200 32MB HD's in RAID 0
- 2X Samsung 830's 128GB in RAID 0
- Windows 8.1 Pro x64
- Coolermaster HAF-XB
- Dual Asus ProArt PA248Q 24" IPS LED Monitors
- Samsung 46" 5600 Series Smart HDTV
- iPhone 6 Plus 64GB AT&T & Xbox One
UNOFFICIAL Rampage II Extreme Thread
I guess above one is PALIT custom made 470 & if it does ......... its vcore may not be adjustable .
I would expect any one buying this would suffer as Sapphire toxic 5870 blue PCB ones
Does that kind of cooler exhaust the hot air into the case?
Phenom II 945 (95w)@3.5Ghz
Geil BlackDragon 1066 2x2GB
Gigabyte 790X UD4P
WD 640GB Black
Gigabyte GTX 470
Corsair HX620-Hiper Anubis case
Windows 7 Home 64bit
Samsung 27" monitor
Gaming Box
Ryzen R7 1700X * ASUS PRIME X370-Pro * 2x8GB Corsair Vengeance LPX 3200 * XFX Radeon RX 480 8GB * Corsair HX620 * 250GB Crucial BX100 * 1TB Seagate 7200.11
EK Supremacy MX * Swiftech MCR320 * 3x Fractal Venture HP-12 * EK D5 PWM
The heat pipes and fins don't look near as heavy as the stock cooler. And with the heat being added to the case if there is a drop in temps the hotter case temps in some rigs will make it pointless. It looks like a AC design under there. You know if AC puts one out it will have 3 fans and be alot bigger.
i7 920 @ 4GHz 1.25v
GTX 470 @ 859MHz 1062mv
I don't mean to jump in here and disrupt a perfectly good speculation fest by interjecting some info the net actually HAS about this cooler (sarcasm intended), but there ARE some fairly reputable sites reporting it to have heat pipes, copper based HS, not to mention being considerably longer with greater fin area. Not only that, there's pics showing rear exhaust fan slots, so why the trash talking speculation people?
There's also claims (Palit's no doubt) that the temp result is 12c lower at load and 4db quieter, which seems reasonable given the details. Now only one site gave mention of whom designed the HS, so I'm not sure that's legit info, but they said it was designed by Thermalright. If that's the case these cards certainly won't be cheap even if not OCed, as some of the sites are saying.
I'm not saying anything's proven one way or another performance wise on this cooler, but for God's sake give the speculation a rest and at least wait to comment until some legit tests have been run.
Here is a reference for you guys: I have the Gigabyte GTX 470. MSI Afterburner
installed and set to 55% idle fan speed. Its pretty quiet at that setting and keeps
the temp at 39c to 40c. The room is 71f. During heavy gaming with the game
Stalker (heavily modded), the fan speed goes to 75% and holds the temp at 74c.
At 75% fan speed, during gaming I don't notice it at all. No headphones. I'm
sure it could be heard if not for the sound of the game. I feel that this 75% fan
speed is fine. You might feel different but it took a big game just to get it to kick
up to that speed. Using the Hiper Anubis case w/3 120mm fans.
This is factual and might be a decent comparison for judging an aftermarket
cooler.
Gigabyte 790X UD4P
WD 640GB Black
Gigabyte GTX 470
Samsung 27" monitor
mmm not bad
Intel core i7 980x
6GB mushkim
ASUS Rampage 3 Extreme
EVGA GTX 580 SLi
LG L246WP Widescreen
Auzen X-Fi HomeTheater HD
Corsair HX1000w
WD Velociraptor 600GB Raid 0 l WD 1TB Black l Intel X25-M 80GB G2
Silverstone TJ07
OCGuate!
Gaming Box
It's pretty loud at just 80% from what I've read, let alone 100%, and at full speed it can easily disrupt conversations, unless you like talking at around 90db. I plan to wait until the non pre-order customers review these and more after market air cooling solutions come out. Seems to me so far those whom have them give overly glowing reviews.
I can assure you that at age 54, I'm too old to "glow"...LOL. Trying to be completely honest here. No real difference between this cooler and my GTX 260
or GTX 275. I'm sure at 100% it IS loud although I've never had it there. The
sound is just one of AIR moving...no whine. I just got mine - no pre-order.
Gigabyte 790X UD4P
WD 640GB Black
Gigabyte GTX 470
Samsung 27" monitor
I just got my Gigabyte GTX 470 as well and here's my take on noise. For people who say it's inaudible at 70% they probably have hearing problem since even though it's not that loud, I just can't stand using it on a daily basis with my fan speed @ 70%, anything under 60% is okay and 50% seems to be inaudible but over 70% and it will start whinning like a pig LOL. Once again it's probably because I use it in my CM 690 II Advanced case and the GTX 470 is the loudest component in my case when set the fan over 60%, and I'm sitting right next to it.
As for temp, I ran Furmark at 1920x1200, 32x MSAA for about 20 mins with fan set to 80% and the max temp is 84C. I played Metro 2033 for 10-15 mins with fan speed at 50% and according to GPU-Z, the average temp is about 94 and max temp hits 105C. LOL. My conclusion is never set fan speed under 70% when gaming unless you wanna kill your card soon.
CPU: Core i7-2600K@4.8Ghz Mobo: Asus Sabertooth P67 Case: Corsair 700D w/ 800D window
CPU Cooler: Corsair H70 w/ 2 GTs AP-15 GPU: 2xGigabyte GTX 670 WindForce OC SLI
RAM: 2x8GB G.Skill Ripjaws PSU: Corsair AX850W Sound card: Asus Xonar DX + Fiio E9
HDD: Crucial M4 128GB + 4TB HDD Display: 3x30" Dell UltraSharp 3007WFP-HC
Speakers: Logitech Z-5500 Headphone: Sennheiser HD650
Thanks Travis, sounds about right, and why I'm leaning more toward a temp get me by card on my new build, then a 28nm Fermi come next yr. I have a line on a once used EVGA GTS 250 Superclock for $80 with shipping included.
The more I read about these cards the more I get the feeling they're just too power hungry to ever be as efficient in performance to noise/temp ratio as I'd like them to be. I'm doubting any dual slot after market cooler will make much of a difference either.
At some point you have to wonder if trying to make these cards run more efficiently is like trying to stuff a watermelon in a banana peel. The current Fermis are overweight, like it or not.
a 250 is a great card...
and very power efficient...
about the 470s and 480s...
well, they come with pretty much top of the line heatsinks already...
i think a 470 with a 480 heatsink would be sweet... but besides that all you can do is go h20...
so yeah if you care about heat, noise, power consumption then the gf100 cards arent the best buy... on water they might be ok, but then again all that heat is going to end up in your room one way or the other
If temp is what you concern most then you'll be annoyed with the GTX 4xx series, the idle temp is good but definitely not under load, WC is seem to be the only solution but not everyone wanna buy a card and think about putting it under water, especially the mainstream user or even some enthusiasts like me.
Anyway it all comes down to price/performance, if you can get the GTX 470 for around $300 like I did then it's a good buy. I'm gonna let it go soon and get the GTX 480 to play around with it.
