Hello - I've built quite a few systems but this is my first venture into liquid cooling so I'm back to being a Noob in this instance. This is my first post here.
I've begun leak testing and so far so good. However, I'm running with the reservoir nearly full and it doesn't appear that much water is being moved. My loop is Reservoir->Pump->CPU Block->Radiator->Reservoir. The pump is set at max (5). The reservoir is at the highest point in the loop and there there is absolutely no air remaining in the loop. Also, The pump occassionlly makes a brief sound like sucking on a straw after you've reached the bottom of the drink.
Any advice would be greatly appreciated.
