I am new to WCG and I have this in the messages of BOINC Manager.
http://i942.photobucket.com/albums/a...incmessage.jpg
Is there a setting or something to fix this ? or is it nothing to worry about?
No, it's not as long as your computer is still crunching theres no problen
You have reached your daily quota of work units. You won't get more until the new day starts - 00:00:00 UTC (Universal Time Coordinated which is similar to Greenwich Mean Time). Around 7pm EST.
Each day your machine gets a certain number of work units. This is based on the crunching power of your rig. If you have a multi-core/multi-thread CPU, you'll be able to process more work units in a day, so you are given more WU's than, let's say, a single-core machine.
Audentes fortuna iuvat
"Fortune favors the bold"
Seems like that you've been erroring out the WUs, is your OC stable?
What prime test did you run? I thought my OC was stable before after running 2 hours of Linpack, but OCCT managed to find an error in ~35 minutes. I tweaked it a bit further and finally managed to pass the standard "CPU: OCCT" test. (1 hour, Medium Data Set, Priority Normal). After I managed to pass that test, it's been rock solid stable. Did 24h of prime blend and has done over 48 hours of WCG with Milkyway@Home loading my GPU as well, without a single error.
To check to see if you're getting errors, go to your WCG My Grid page. On the left-hand side, click on Results Status. On the second drop-down menu, go to Error and then click Filter.
Errors are one reason why you can run out of your daily quota of work units. There are other reasons. If, for example, you reset the project, BOINC will flush out all your cached work units. If you flush out a full day's worth of cached WU's, chances are you won't get anymore for that day. Under normal circumstances, though, you shouldn't run out of work units. The new day starts about two and a half hours from now.
Thanks for your help.
If you just installed BOINC today and connected to WCG, you will have a limit on how many work units you can download. The issue should resolve itself this evening (if your in North America) when the quota resets itself at midnight UTC. As long as your machine doesn't return a bunch of errors or invalids, you'll never run into the quota limit again.
i7 3970X @ 4500MHz 1.28v
Asus Rampage IV Extreme
4x4GB Corsair Dominator GT 2133MHz 9-11-10-27
Gigabyte Windforce 7970 OC 3-way Crossfire
Windows 7 Ultimate x64
HK 3.0-MCP655-Phobya 400mm rad
Corsair AX1200i
Sandisk Exrtreme 240GB
3x2TB WD Greens for storage
TT Armor VA8003SWA
