Okay you guys warned me before going water that it is addictive and you always want to get better parts and lower temps, you were right.
So it's time for an upgrade.
first the current situation.
Loop1
mcp355 in a xspc bayres
heatkiller 3.0 CU
XSPC rx240 with 2 GT 1450's
Loop2
2x bitspower black freezer GTX295B
xspc rx360 with 3 GT 1450's
I'm want to consolidate the 2 loops and form one big loop with 2 pumps, i'll be using the EK-dual DDC turbo V2 with an EK tuberes.
The rads will be replaced by a phobya xtreme 1080 rad with 9 yate loon 1350 RPM fans.
Will my temps improve if I buy and install these components.
My second question is regarding the fans. I'd like to hook up all the fans via this cable http://www.aquatuning.nl/product_inf...--Schwarz.html will this give all the fans enough power to run at 1350 rpm.
Thanks in advance
