Results 1 to 19 of 19
Thread: GTX 480 hot - NOT
    Nov 2006
    Cool GTX 480 hot - NOT
    So, I've played around a bit with my GTX480
    The block is old / small and cost all of 10$ ages ago.. The shroud over the ram is made from plastic and is just there to act as a heat shield. So theres no need to cool anything apart from the CAPs at the end. I kept the fan there and its running at ~20%.
    The IHS is higher than the plastic so you can use a bigger block.
    Running:
    and wait for it....
    50C I had other runs with different AA levels, but theres a bottleneck somewhere with current drivers for its a few C cooler Same system with a GTX 280 EK full cover gave 55C..
    Q9650@4000 - Apogee GTX, Gigabyte X48-DS5, 8GB Corsair Dominator XMS2-8500, GTX480 El cheapo Asetek block, Audiophile 192 + Adam-A7, Win7
    Banned
    Jul 2009
    nice not bad, so this tells us something, obviosly the gpu puts out more heat than the stock cooler is rated for, meaning nvidia either cheaped out on the cooler design or rushed it out so as not to delay the cards any longer.
    I am Xtreme
    Feb 2007
    Quote Originally Posted by overclocking101 View Post
    or it means water-cooling does an effective job of removing heat . . Nvidia did make sure a block would be available at launch. not sure how much more you can do with an air-cooler. When someone posts an aftermarket air-cooler that would be feasible as a retail OEM/AIC solution then you can comment
    "Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
    Dec 2008
    Franklin, TN
    Just got My GTX 480's today. I ordered the Koolance blocks as they came back into stock today, so looking forward to see what temps I get....
    (New build):MSI Big Bang X-power II with XSPC MB blocks, Core I7 3930k@4.6Ghz with HT on, 3x GTX 480 SLI with EK Waterblocks(for now), X-fi Titanium, Gskill quad kit 16GB 2133mhz, 2x240GB Corsair GT SSD's(raid 0), 3xWD 2TB drives, Silverstone Strider ST1500 Watt, Dell3007WFP and 2x Samsung 305T's. Water loop: EK HF CPU block, XSPC RX480 Rad, Coolgate GC480, Airplex Revolution 420 Rad, 2x DDC 3.25 18W with EK dual top, Caselabs STH10 white with customizations....
    Jan 2008
    Edit - Thread title "Diclaimer, only with watercooling AND fan..and personal fire brigade"
    Nov 2006
    Quote Originally Posted by DarthBeavis View Post
    Yeah, theres not much you can do with a 2slot card. Surface area is surface area..
    I am Xtreme-ly Unemployed
    Nov 2005
    Palmdale, CA USA
    Stock coolers on video cards have pretty much always been junk... they design in just enough robustness to prevent the GPU from cooking (granted, there are a few exceptions).
    Reminds me of people complaining about the HD4850's dumping a lot of heat (you could burn yourself on the cooler and the GPU would hit 80c+ at load) when, in reality, they dumped hardly anything... the stock cooler was just junk. Put 'em on old MCW60's and you'd be lucky to see 'em break 35-40c at load when overclocked. Heck, I have an HD4850 running passive in my HTPC with a modified Arctic Cooling Accelero S1.
    Anyway, my point is that people tend to overestimate thermal output when they're basing their estimate on the performance (or lack thereof) of a video card's stock cooler.
    I'm doing science and I'm still alive...
    I am Xtreme
    Feb 2007
    Petra should consult with AICs on designs for stock aircooling
    Dec 2009
    Finland
    Seeing how new parts continuously keep getting hotter and hotter. I'm happy that I moved into watercooling . Never used stock coolers anyway but I wouldnt be surprised if market aircoolers wouldnt do the job soon anymore either . Unless you use them with san aces or smth...
    Specs:
    HW: Lian Li PC-A71F | i7 920 | P6T Deluxe | HD5870 | 6GB OCZ Platinum 2000mhz | AX850W | Asus Xonar D2X 7.1 | Intel X25-M 80GB SSD | WD 2TB Caviar Green
    WC: EK-FC5870 | EK Supreme HF | Swiftech MCP655 with EK top | ThermoChill PA120.2 | ThermoChill PA120.3 | EK Multioption 250
    Other: Scythe Gentle Typhoon fans | Aqua Computer Aquaero | Bitspower Comp. Fittings
    Jul 2009
    Finland
    Gilhooley, what pump/radiator are you using?
    Jul 2005
    New York
    Nice results...hopefully it leads to some decent overclocking. The stock cooler seems to be pretty close to capacity.
    Nov 2006
    Quote Originally Posted by mrcheeky View Post
    The CPU /GPU share 2xThermoChill PA120.2 (~1500rpm fans) and a Laing DDC - 1Plus.
    Dec 2009
    Functionality over beauty all the way
    Mar 2009
    Its stil kind of "hot" for a stock clocked card under water ...
    BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
    Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
    Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
    Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
    Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
    KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
    Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
    Sep 2008
    Las Vegas
    Quote Originally Posted by Boulard83 View Post
    not really.. 47C load when the DD and Swiftech are getting 49-51C... Fermi runs warm. anthing under 55C is good
    Project HAF 932 Water-Cooled
    __________________
    New OC Validation
    - Q9650 4.0 Ghz For Now -
    - GTZ, Feser 360, D5 Vario, EK Multi-Option -
    - eVGA 750i FTW! -
    - eVGA GTX 480 H20 & GTX 295 -
    - 2x2GB Dominators PC2-8500C5D -
    - WDCaviar Black 640GB AALS x2 (Raid0) -
    - FreeAgent Pro 500GB Ext x2 -
    - Enermax Revolution 85+ 1050w PSU -
    - X-Fi XtremeGamer -
    - CM HAF 932 H20 -
    - Dell U2410 IPS LCD -
    - Logitech G11 & MX-518 /G9 -
    - Sony 24x Optical w/ LightScribe -
    - BOSE Companion 3 -
    - ATH-AD900 Cans & UE Triple.Fi 10 Custom IEM's -
    - Nikon D40 w/18-105mm & 55-200mm VR's -
    Oct 2009
    East Coast
    I think people get to hung up on temp.. Fermi dont mind heat.. any block you use to cool it with is better then air and alot quieter. 1-5c not going to change how well it overclocks
    Core I5 750 4Ghz
    4Gig Ram
    Koolance 360 CPU BLOCK
    Exos 2.5 1/2 Tubing
    EVGA GTX 480
    Danger Den GTX 480
    Nov 2003
    NYC
    its a 5 heatpipe HDT cooler, its very beefy for a factory solution
  18. #18
    May 2008
    Miami,Fl
    Well, isn't the expected heat assumed from the power consumption benchmarks. I've seen a few reviews where the gtx480 consumed more power than a 5970. Maybe the inefficiencies are tied up somewhere on the board but not on the actual gpu. Maybe some tests of the thermals on different areas of the board will actually resolve this.
    I'm still on the fence about getting one, but I'm excited at what a revision, process shrink, and driver improvement may be able to do over the course of the next 6 months. The shrink for the g92 from 65nm to 55nm was pretty amazing from a power consumption standpoint.
    Regardless, it's pretty impressive to get lower temps on the fermi vs the gtx 280.
    @Gilhooley: Are there other temps being displayed by gpuz that aren't viewable in the screenshot. Can you show us if their is?
  19. #19
    Nov 2006
    Quote Originally Posted by avddreamr View Post
    Nope, only fan and load values below.
