I have a Corsair HX1000W at the moment and would like to sleeve it but I've seen the bulbous amounts of heatshrink that are involved around where the wires come out.
I need something of comparable performance but that is fully modular.
Thanks!
Thanks!
I would think almost any PSU you change to after that HX1000W is downgrading, but anyway, i quite like the 1000W Silverstone SST-ST1000-P. Fully modular and it doesnt do too badly at johnnyguru.
Zombie Killer Corsair 700D with Quad Rad mod+240 rad mod/Asus Maximus III Formula/i5 750 @ 4Ghz/8GB GSkill Trident/HIS HD 6990/Dell u2711/120GB Kingston SSD Now!/All under EK watercooling goodness!
HTPC Lian Li V354B/i5 750/4GB Corsair/MSI HD5770/60GB GSkill Phoenix/Corsair H50/EVGA P55 Micro SLi
fully modular, only ULTRA x3 line, that rings the bell
Raidmax ATOMIC - Core i7 3770s + Corsair H70 // Gigabyte H77N WIFI // Corsair Vengeance 2x4GB 2133mhz // EVGA GTX1060 ACX2.0// Kingston SUV400 480Gb // Sharkoon SFX500L
I second the 1000W Silverstone SST-ST1000-P suggestion.
Yes the silverstone... It was on sale at Tiger Direct plus you can get 8% cash back if you use Bing.... Just a thought...
Windows 7 64 Bit
BenQ FP241W Black 24" LCD
Mountain Mod Case w/ Base
Asus Rampage III Black Edition
i9-990x @ 4.58GHz - 1.36v Temps (Idle 23C - Load 48C)
12GB Corsiar Dominator GT (PC3 15000) @ 9-9-9-24 1T - 1.65v
Sapphire 5870 x3 "OC" w/ EK Water Block Temps (25C-49C)
EK-Supreme / 4 Alphacool Laing DDC-Pump Ultras + Extras
Power Supply / 2x Silver Stone DX1000
Western Digital 1.0TB x 3
Crosair SSD 128GB x 2
World Community Grid!
But that Silverstone PSU has those big 'ol capacitor things on the ends of the PCI-E cables.
HEATWARE
x58-UD5 ▀▄ i7 950 4.0Ghz ▀▄ ZOTAC GTX 580 ▀▄ Mushkins 1600Mhz
is there any reason for these capacitors? i usually make my own cables for modular supplies, and just picked up a st85f-p. it has these capacitors as well. do i need to add these to my new cables, or can i just get rid of them? my only thoughts are that the caps are there to prevent a surge of power at start up. why they didn't make that internal puzzles me...
Not From Concentrate
All Projects
Previous Projects:
S3 Mini ITX Chassis
The ArK
Uriel
Israfel
Veritas
Eldritch
From fully modular PSUs i'm currently thinking about Corsair AX1200. Stable voltages, gold efficiency, full modular cables, nice black looks. Pitty that nothing said about quietness of fans.
Ah ha, makes sense. thanks NFC. i am almost tempted to reuse them and splice them in to my new cables but we'll see. do they have to be so close to the connector that plugs into the videocard? or could i put them more toward the end that plugs into the psu? they look very awkward and bulky when dangling on the vid card. if i could hide them toward the psu i'd be more tempted to include em. but as you said i probably won't notice their absence, especially with my 5.1 cranked up, haha...
well the higher efficiency will lead to less heat, which in turn should result in less fan speed and thus less noise. and its got a 140mm fan to reduce db's per cfm even more. i got the st85f-p and its got a 140mm fan. she ran near silent when i benched my new build but i have yet to put it under load, i just wanted to make sure everything worked before i swapped to wc. you could always open her up and do a fan transplant if its too loud. did that on my old st60f and boy did it help
A minor thing to think about too (while we are comparing the two) is that the Silverstone is MUCH easier to sleeve for whatever reason. Corsair PSUs are a and a half. I was using them exclusively until someone on these boards recommended I try the SS, and the cables just pull out like dandelion seeds with Nils' tool.
This shouldn't be the only reason you base your decision on, but I thought I would mention it.
And I know you said you are looking for fully modular PSUs, but if you are going to make your own wires anyways, I _highly_ recommend the Coolermaster ULTIMATE. The performance is outstanding and all that, but it is extremely easy to sleeve, comes with long cables so you only have to subtract, not add, and the wiring it uses is extremely flexible.
I void warranties on all my PSUs so I'm biased in that region. =P
All Projects
Previous Projects:
S3 Mini ITX Chassis
The ArK
Uriel
Israfel
Veritas
Eldritch
I just ordered the new Gold rated Corsair AX1200 Full Modular Planning on sleeving I will let you know
The good thing about fully modulaire PSU is that you don't need to touch the wire from the box, you just buy cable, pin and new plug and make a new one (and your warranty is still there)
Some modular PSUs have very non standart-ish connectors on PSU side for wires.
► ASUS P8P67 Deluxe (BIOS 1305)
► 2600K @4.5GHz 1.27v , 1 hour Prime
► Silver Arrow , push/pull
► 2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
► GTX560 GB OC @910/2400 0.987v
► Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
► CM Storm Scout + Corsair HX 1000W
► EVGA SR-2 , A50
► 2 x Xeon X5650 @3.86GHz(203x19) 1.20v
► Megahalem + Silver Arrow , push/pull
► 3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
► XFX GTX 295 @650/1200/1402
► Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
► SilverStone Fortress FT01 + Corsair AX 1200W
Here's a review by JonnyGuru on the AX1200 (Review)
Looks to be a dead set stunner!
that's exactly what i do. so easy and looks so nice when everything is made to length. just remember "continuity is your friend!"
when this happens i just take note how the connectors are used (which wires go where) and then reuse that connector with my new cables...
thank you, good to know. i think i'll play it safe and splice them in. i think i'll try putting them toward the psu (since its hiddenish) rather than at the end of the cable by the vid card. i don't think i would affect anything...
