Results 1 to 4 of 4
Thread: Looking for help for project due thursday
    Oct 2006
    A place the sun don't shine (Seattle)
    working on an imaging processing assignment with noise addition and reduction. part of the assignment is to add white gaussian noise to an image.
    we were given the website http://www.dspguru.com/dsp/howtos/ho...gaussian-noise
    to help with the assignment, and i did my best to follow it but i cant find any white gaussian noise images with variance and mean values to go with it so i dont know if what ive got it right or not.
    and second it has to be done within a console and i have not done much of anything with console's before. ive been given console's for other assignments in C++ but dont know how to make one myself. my classmates say c# is the way to go but havent touched that either. would it be easier to learn C# and make a console or rip out an old c++ console and fit it for what im doing?
    Intel C2Q Q9550 2.83ghz :: Intel DQ45CB :: 4 x 2gb OCZ DDR2 PC2-8500 Reaper HPC :: ASUS EAH5850 :: Thermaltake TR2 RX 750w :: Western Digital Caviar Black 4 x 750gb in RAID 10
    Intel e3-1235 3.3ghz :: Intel s1200kp :: 4gb kingston hyperX 1600mhz :: WD 500gb Cavier Green
    Intel i7-3770k 4.4ghz :: msi z77ma-g45 :: 8 gb patriot Signature 1600mhz :: 160gb WD Cavier :: 5830 + 5870 CF :: Antec Earthwatts 650w
    "...all men die, and no brave man lets death frighten him from his desire..."
    Jan 2009
    Chandler, Arizona
    What platform are you developing on? And by console do you mean a GUI or a command window? I probably can't help much with the white noise portion but may be able to point you in the right direction for languages/platforms.
    -trekie86
    Antec 900 Black
    Rosewill 600W RP600V2-S-SL
    Gigabyte EP45-UD3P Rev 1.0
    Intel E8500 @ 3.8 GHz
    2 x 2 GB GSkill PC6400
    EVGA Geforce GTX 260 Core 216 SSC 55nm
    EVGA 8800GTS PhysX
    640 GB WD HDD 7200 RPM
    Quote Originally Posted by dengyong View Post
    Started life as a FTW and ended up as a WTF.
    Oct 2006
    yea sorry, by console i mean GUI. not sure which would be easier to work with at this point in time
    Jan 2009
    Chandler, Arizona
    I don't know if C++ would be the easiest language to use to create a GUI and manipulate your white space generator. Personally I think java is a better solution for creating a GUI and is easier to make changes by just establishing a listener for the adjustment object. Really any programming language with a Math pack can do the calculations necessary for the white space adjustments. Sorry I can't be much help. Good luck. If you are familiar with C++ already and have a GUI already setup, go with that. Sometimes learning a whole new language for one little thing isn't worth it. If you want to go out and just learn C# for future use, go for it. Its a good language with a lot of growth potential due to the .Net framework.
    -trekie86
    Antec 900 Black
    EVGA 8800GTS PhysX
