Cant get games to run in both screens, MW2, HL2 doesn't detect the resolution? Dual Screens only work on the desktop.
Im using windows 7 BTW.
GIGABYTE 790XT - AMD 955 3.4Ghz - CM V8 - OCZ Reaper 8GB 1500Mhz - Sapphire 4890 2GB 950/1125
You need eyefinity, triplehead or such to do that
Asus Crosshair IV Extreme
AMD FX-8350
AMD ref. HD 6950 2Gb x 2
4x4Gb HyperX T1
Corsair AX1200
3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
I'm not sure it's possible to do with dual monitors but I'm sure it's not possible on 4xxx series. It is a feature on 5xxx series...
You could game on two monitors acting as one?
yes
Edit: 2.... not 3 and last time I tried I wasnt able to. I suspect the OS change or newer drivers didnt support it. Last time I was able to, I was probably using win xp and old cat drivers developed during 3870x2 era. Back then I was able to choose a option called "Span" and it would span windows across dual display. Extend, Clone, and Span.
