I sure wish we had another update for the Destroyer that would enable and allow for the use of AM3 Ph II X6 CPU's
I dont' get it man. I have a way older ASUS M2N32 SLi Deluxe that I can use my Ph II X4 955 BE on and it works just fine w/the exception of having to use Nvidia Sys Tools to make the CPU run at the right CPU multi and clocks.
Any way all I'm saying is if ASUS can do it w/a board that was the flagship board for the realease of AMD's AM2 line of CPU's then Foxconn can surely put out a Ph II X6 supported Beta bios so they are not liable for any hardware damages should the CPU's draw to much power and over heat the voltage regulation circuits. I doubt that would happen but any way.
Come on Foxconn. Please give us a last breath of life in our aging Destroyers so that we can restore faith in your products and feel good about buying into your higher end Intel line up of boards.
Just food for thought and hoping you'll give it another shot.
I'm out,
N2G
