+ Reply to Thread
Results 1 to 13 of 13
Thread: Dead PSU's
    Xtreme Cruncher OldChap's Avatar
    Mar 2008
    Plymouth (UK)
    98
    Dead PSU's
    Not such a good couple of months ....
    First to die was a PC P&C 1k SR...no power good signal???
    Then Coolermaster 900 UCP .....Plug in tester and standby power only
    Today Coolermaster 1100 UCP ....Connect to mains and breaker trips (so 3 rigs off all day) This one might be under warranty...hopes
    Had to remove a GPU to be sure but replaced with a zippy emacs 510w that I picked up for £1.00 + postage took me an hour to find enough adaptors to power the HD and graphics
    POLITICAL CORRECTNESS:
    A doctrine, fostered by a delusional, illogical minority.
    Xtreme crazy bastid D_A's Avatar
    Apr 2007
    In the middle of an Auz fire zone.
    0
    You are running them all with at least surge protection I hope.
    Nanoseconds from Permaban [XC] Oj101's Avatar
    Jan 2006
    South Africa
    268
    Ouch, I very nearly bought a UCP 700w (which did well for the price at JonnyGuru) but now I'll steer clear of the CM range. You're popping PSUs at quite a rate, do you have clean input power?
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    45
    If you were in the states I'd say send them to me, I want to try to fix one of these things sometime. Already rebuilt the power supply in an LCD monitor I have as my 2nd screen now, I want to go after something more complex next
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
    Mar 2008
    Plymouth (UK)
    98
    I doubt the power not being clean, but I only have surge suppression. These have all run for a good while mostly at or above 75% load
    Xtreme Cruncher Duh's Avatar
    Dec 2005
    L.A. ( Latin America)/ 4socket wannabe
    15
    I'd take a look at at a line conditioner as Serra ( Xs user) recommended me some years ago ( not a single hitch after I bought that APC bastagge)
    "Study hard my young friend"[/B].
    Woody: It's not a laser! It's a... [sighs in frustration]
    Mar 2008
    Plymouth (UK)
    98
    like this? http://www.apc.com/products/resource...se_sku=LE1200I or is there a whole house option cos one of these per rig is a bit of a pain and $$$
    Dec 2005
    15
    THATS what I am talking about ( same model ). Payed 70 bucks back in the day
    Apr 2007
    0
    Yes, you can (if you have the $$$$$$$$$$$$) get a big enough UPS (or line conditioner if you don't want the battery back up) to cover your whole house. I've worked around systems that can keep the control systems of a whole power station running for several days on backup power.
    Xtreme Cruncher skycrane's Avatar
    Jun 2005
    Northern VA
    2
    Old Chap, i looked on craigslist for ya, there is absolutly nothing on your side of the pond i have a apc matrix 5000VA thats been running nonstop at 95% for the last 5 years with no problem.
    heres a repsentation of what they are.
    http://cgi.ebay.com/APC-Matrix-5000-...item27b0d4733f
    ive looked on ebay.uk for ya, and nothing there. Dont worry, you cant ship it, the PU is 120lbs, the ECU is 90lbs, and the battery packs are 60lbs+
    Its not overkill if it works.
    Mar 2008
    Plymouth (UK)
    98
    Thanks for that. I have seen similar on ebay UK ...guess I'll just keep looking...usually costs though.... http://cgi.ebay.co.uk/APC-5000-VA-UP...item27afe95383 and http://cgi.ebay.co.uk/APC-3000-Rackm...item5ad804dc12 and maybe http://cgi.ebay.co.uk/APC-1400-2u-RA...item5d267b7449 show what I would need to pay so maybe one of the first seen for each would be cheapest
    Xtreme Cruncher anubis's Avatar
    Feb 2003
    Estonia
    14
    Yup get a good UPS, no money better spent for me than a huge battery to keep the line stable for my precious. Nothing like a nice sine wave from 1500va UPS that keeps it crunching 100% for 30 minutes after full blackout
    And also, its fun to look at the logs later on, i had 1 pc killed due to my elec company, when i got UPS afterwards i understood what the poor thing had to go through. Spikes all over the place. Not a good sight...
    edit: there, isnt she beautiful?
    Member of XS WCG since 2006-11-25
    Jun 2005
    Northern VA
    2
    OC, i know what kind of rigs your running, so the last 2 you linked to wont do it. youll max them out in a heartbeat. imo, the first one is the one you need. its just like the one ive got, except that one is for a rackmount, and mine is a floor one. 520L, that about what $700 us ? thats a fair price, the only thing i dont see on it is the connections for any aux battery packs.
    http://cgi.ebay.co.uk/APC-Smart-UPS-...item5ad8348404
    it looks like the batts come with the usp, but they look like small ones to me, youll only get about 6 min of runtime at full load although considering full load is 5kw, thats not to bad.. lol
    if you look on the us ebay.com site, and search for apc matrix, you will see the ones like i have.
    the only thing wrong with these are the batteries, it runs at 48V DC so if you need to replace them, your going to need 4 at a time. it can get a bit expensive.. but ive had mine running for 5 yrs now and havent had a problem with the batteries, so they should last a long time....
    EDIT, looking back at your main post, for the price of the dead psus, the 700$ for this seems like a good deal.
+ Reply to Thread
