The 980x has a TDP of 130w
Anandtech's 980x setup at 4.13Ghz had a power consumption of 205w
http://www.anandtech.com/show/2961/i...z-with-6-cores
So lets say the heat load is 205 watts.
Lets say we use the 19911-5M31-28CZ
peltier from
http://www.customthermoelectric.com/tecs_Qcmax.html
Specs
Qmax 400watts
dTmax 62 C
Vmax 24.8vv
Imax 28 amps
Lets say we run the peltier at 75% power, 300 watts.
The difference between the hotside and coldside of the peltier will be
Delta T = (1 - (Heat Load/Max Cooling Power)) * Max Temp Difference
Delta T = (1 - (205/300))*62 = 19.6 deg C
The peltier hotside will be
cpu watts+ tec watts = 205+300 = 505 watts
Lets assume a perfect world for simplicity
Ambient would be 22C
CPU surface would be 22C-19.6 = 0.4C
Then a rad setup would need to handle 505watts
First, are these calcs correct?
Second, I know I said a perfect world, but how far is this math from reality? Assuming I use a cpu peltier waterblock.
