Results 1 to 6 of 6
Thread: Mix and Match Brands?
    Dec 2004
    Southern California
    Hey guys im about to pickup another 5870 for some xfire action, i have an Asus 5870. I cannot find the same one in stock anywhere now, newegg has this new v2 that only has 1 dvi and 2 hdmi ports. Can i mix xfx with asus?
    i9-10900k@5.3ghz//MSI MEG z490 Unify//32GB Gskill TridentZ b.die@DDR4666//RTX 2080ti(+150/+700) kingpin bios//Samsung 970 Pro//Corsair AX1200i
    Custom Loop: Dual DDCs->Dual EK XE360 w/GT's -> HK IV CPU -> HK IV GPU ->EK X3 Res controlled by Aquaero 6
    NooB MOD
    Jan 2006
    South Africa
    Yip.
    Shortest lived thread ever?
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    Mar 2010
    Puerto Rico
    Quote Originally Posted by Circaflex View Post
    the v2 actually has 1 x dvi, 1 x hdmi and 1 x display port
    Dec 2004
    Southern California
    what about mixing v1 with v2?
    Mar 2010
    Puerto Rico
    from the looks of it you can mix 5830, 5850, 5870 and 5970 don't see why not v1 vs v2. And from looking at your other thread its most likely the pcb design to be different so water blocks should be different.
    i7 860 @ 4.3 GHz || Gigabyte GA-P55A-UD7 || G.Skill Ripjaw 8GB 2000MHz w/ Fan || Swiftech XT CPU Block
    MCP355 w/ XSPC Res Top || MCR320-QP || 2 x BlackIce GTX 120|| WD 750GB Caviar Black RAID 0
    Corsair HX1000w || CoolerMaster ATCS 840 || OCZ Agility 60GB SSD RAID 0 || Lamptron FC-5
    2 x Asus EAH5850 DirectCU TOP w/ EK Nickel/Acetal Water Blocks || EVGA 8800GTX physx
    Dec 2004
    Southern California
    WEll that sucks that the new Asus is probably a different PCB which means waterblocks might not work... maybe i can pickup a used one or a different brand and bios flash
