Asymmetrical GPU setup?
Hello all,
I'm new to the GPUGRID stuff but want to help with it;
Is it possible to run an asymmetrical GPU setup with BOINC/GPUGRID?
For instance, First PCIe slot is a GTX260, second slot is 8600GT, etc,?
"Red Dwarf", SFF gaming PC
Winner of the ASUS Xtreme Design Competition
Sponsors...
ASUS, Swiftech, Intel, Samsung, G.Skill, Antec, Razer
Hardware..[
Maximus III GENE, Core i7-860 @ 4.1Ghz, 4GB DDR3-2200, HD5870, 256GB SSD]
Water.......[
Apogee XT CPU, MCW60-R2 GPU, 2x 240mm radiators, MCP350 pump]
Crunching For The Points!
subscribed.
i know you can do it and i will be doing it just dont know how lol..
As long as the cards have the same CC they should. But I am not sure the 8600 will work ok. Many of the older cards no longer work due to programing changes. You will just have to try it. When you start up Boinc look for the cards in the Messages Tab and it will say what CC they are.
to the team!
- You may not post replies
- You may not edit your posts
Forum Rules
