Results 1 to 12 of 12
Thread: Moving water uphill with no pump
    Dec 2008
    Hey guys, just came across this, thought I would share. Could lead to some interesting developments eventually. Feel free to move if this thread should be somewhere else. Just figured it was liquid cooling related.
    http://rochester.edu/news/show.php?id=3566
    Mobo: DFI X48 T2R
    CPU: E8400 @ 3.78 (lil better)
    Ram: G.Skill F2 Pi @ 840
    GPU: 2x HIS IceQ4 4870 1gb X'd
    HDD: 2x Caviar Black 500gb
    Cooling
    GTZ, FC EK's, 655B with EK Rev.2 Top, RX120 w/GT1850's push/pull, MCR240 w/GT1850's in push, Frozen Q n Primochill 1/2" Tubin
    Mar 2008
    Minnesota
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Dec 2008
    Haha sorry. Disregard
    Mobo: DFI X48 T2R
    Cooling
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    uses no energy eh?
    wtf is the laser then?
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Nov 2009
    Netherlands
    Quote Originally Posted by NaeKuh View Post
    uses no energy eh?
    Actually the laser is just there to carve the shape.
    Chasing After Diety
    Jan 2007
    Quote Originally Posted by Alexandr0s View Post
    the helps movement no?
    LOL..
    so laser = energy...
    I can say the same thing... moving water in a pot!~
    You boil the water, the bubbles push the water up, along with convection!
    BAM! u got water movement without a pump... oh yeah.. but u poured a ton of energy into it heating the water up.
    Mar 2008
    Connecticut
    LOL..
    Irrelevant. The laser sets the stage for the action to occur. It plays no actual role in the motion, nor does it add any actual energy to the process. Were humans precise enough with a knife they could duplicate the process.
    Chasing After Diety
    Jan 2007
    No energy required in my definition is perpetual motion.
    Its like space, you push something to the sun, it will reach the sun... given in a million years, yet it will still reach the sun.
    You turn off the laser, the water will not move up.
    That is what im trying to aim at.
    Its not Zero Point Energy which the article makes it sound to be.
    Oct 2009
    But without the laser, it would not move, and carving out silicon with a knife still uses up our energy :P There's no doubt that energy is used.
    The energy in setting stage, is still part of the process whether or not it is pre-process, because without this, it would not work.
    There is no force or source of energy on the water itself but to convince it to move, hence moving it, requires the energy of the laser.
    How many other ways can i put it
    Like firing a gun. you can say the bullet, relevant to water in the context it was described in this argument, requires no added energy to pass through a human, but what about the gunpowder?
    dropping a tennis ball: Gravity did the work but Someone or something had to lift it to a designated height first from which it had been dropped.
    etc.
    IF the laser were to carve a path out once, and the water were to continuously move up that path, then that would be setting the stage, but seen as it would have to be done over and over again, it requires energy to move. Yes? Yes.
    Patience is the only talent.
    Chasing After Diety
    Jan 2007
    which is why i said its not zero point energy.
    And i dont think its once, i think the laser needs to be on constantly.
    And your gonna confuse the people with potential vs kinetic energy.
    The article made it sound NOTHING was acting on the water to move it up.
    Which is the definition of Zero Point Energy.
    http://en.wikipedia.org/wiki/Zero-point_energy
    Nov 2009
    Netherlands
    Actually, it has to do with the attraction that the silicon has on the water. However, this attraction disappears when all the silicon is covered in water I presume. Meaning it will not create a loop or something similar.
    Chasing After Diety
    Jan 2007
    (This might seem like getting energy for free, but even though the water rises, thus gaining potential energy, the chemical bonds holding the water to the silicon require a lower energy than the ones holding the water molecules to other water molecules.)
    Chemical bonds (WTF why is he going into chemistry now from physics... wait.. isnt silicon hydrophobic by nature to begin with... can u dissolve sand in water?) Does he mean the hydrostatic force?
    So they got a silicon at the top as a collector? What happens when the collector gets full? and since its an aggressive first come first serve basis, the substrate will get full very quickly and will not want to let go unless they have a greater attractor somewhere else.
    So wtf happens when it gets full?
    I understand what they are saying, but the article is worded so horribly. Its like the author has never written a science paper b4 in his life, or taken a upper division science course.
    LOL i know... so how is this useful?
    At least carbon nanotubes moved the heat as the medium itself, and not a secondary medium.
