Short and sweet. Which is better? Why? By how much? Go!
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
My guess would be that both would sound about the same. The onboard sound of the MB has a few more features, but the Audigy 2 ZS *might* sound a tiny bit better.
Here is the DAC used on the Audigy 2 ZS, spec wise it is very similar to the onboard of that motherboard:
Here is the spec page for the ALC8899 for the onboard sound
http://www.realtek.com.tw/products/p...n=4&ProdID=173
Current:
Asus Sabertooth 990FX
AMD FX-6300 @ 4.74GHz
16GB of Mushkin DDR-1866 RAM (8-9-8-26-1T)
Nvidia GTX 670
Yamakasi Catleap 2B overclocked to 120Hz refresh rate
Audio-GD FUN DAC unit w/ AD797BRZ opamps
Sennheiser PC350 headset w/ hero mod
Do you know if the Audigy has port sensing? Using my onboard I get a dialogue when I plug something in allowing me to select what it is.
I dont think the Audigy 2 ZS has port sensing. That is a newer feature than the age of the Audigy 2
Current:
Nvidia GTX 670
i have an A2plat pro and its better than the gd70 onbloard but there is mic input corruption quite frequently, u just have to reselect the bit rate and it will reset and clear up though
3770k, M5E, kingston 2x4GB cfr
samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
I'm running my Audigy 2 ZS instead of the onboard of my GD70, but that's more because I always have run it, and previously it beat out any onboard sound. Does it now? Not sure, but given that I've been yet to be impressed by every other onboard out there, I just kept with old faithful![]()
The Cardboard Master Crunch with us, the XS WCG team
And put that GPU to work too! Fold for XS
Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
