Hello all!
I was just wondering if it was possible somehow to turn off one gpu when needed? Asking because some games do not support dual gpus and work better with just one.
Thank you in advance!
Hello all!
Just 'cause you feel it, doesn't mean it's there
I don't really know but i thought you could just disable Crossfire in CCC and this should work out!?
Desktop i7 2600 3.40 / Gigabyte P67A UD4 / Armageddon / 4x4GB G.Skill 1333MHz / Zotac GTX285 AMP!
Server Q8300 2.50 / ASUS P5Q-EM P43 / AC Freezer 7 Pro / 4x1GB Kingston @ 800MHz / 6x1TB WD @ RAID 5
HTPC i3 530 2.93 / ASUS P7H55-M Pro / Prolimatech Samuel 17 / 2x2GB Mushkin @ 1333MHz / HIS Radeon HD5570
Notebook: Asus UL30A / Samsung 64GB MLC SSD
There is no CF option in CCC with one card. Only had it before when I used two 4850 cards.
disable Ai
in the control panel and see if that helps
I've put Ai on "disable" long time ago since enabling it makes my screen flash and glitter. Don't know how it could help in disabling one GPU.
If i'm not wrong, u can't disable CF in dual gpu ATI cards...
Project ZEUS II
Asus Rampage II Extreme
Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
2 x Asus HD 6870 CrossFire @ 1000/1100MHz
OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
Watercooling setup:
1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
Assembled in Mountain Mods Ascension Trinity
Powered by Corsair Professional Series Gold AX1200
I discovered a way to do this by accident. I was playing around with the bios for my 5970 and accidentally flashed both cores with a master bios, instead of master and slave. When I got to windows, CCC recognized each core separately and I was able to set CF from the CCC.
Try that at your own risk of course. I didn't do any testing to see if each core was in fact acting separately or not. I just noticed that I could set CF in CCC.
Feedanator 7.0
CASE:R5|PSU:850G2|CPU:i7 6850K|MB:x99 Ultra|RAM:8x4 2666|GPU:980TI|SSD:BPX256/Evo500|SOUND:2i4/HS8
LCD:XB271HU|OS:Win10|INPUT:G900/K70 |HS/F:H115i
all you have to do is disable crossfirex and it shuts down one gpu you can tell because when you go into the overive tab theres no drop down menu for the second gpu......when it anabled theres a tab that drops down showing the second one. This is how it works with my 4850x2 single card.
Drop down menu is right beside the lock/unlock for ati overdrive
AMD 1090T@4.0ghz
Enzotech sapphire/Mo-Ra extreme rad
Asus Crosshair IV Formula
ht 2400mhz / nb 2400mhz
12gb Gskill 1300mhz
HIS HD5970
Enermax Evo Galaxy 1250
case: XCLIO A380PLUS-BK
4.61ghz water
4.5ghz superpi 1M 15.585
http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
Phenom 2 125w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=117414
Phenom 2 140w 965 test results
http://futuremark.yougamers.com/foru...d.php?t=109214
Phenom 2 AM2+ 940 cold air results
http://futuremark.yougamers.com/foru...ad.php?t=97430
If I dont get every single drop out of my cpu I feel like someone is stealing from me
[CENTER]The post counter is not an intelligence meter!Originally Posted by Massman
MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Heat Team IRONMODS
OK, I didn't know that disabling Catalyst AI = disabling one GPU. I've done it since enabling both GPUs makes my screen flicker in most games like crazy. Now I'm back to "crossfire" and trying to find a solution to the old problem (flickering).
I've read somewhere that "connecting another display to the DVI port fixes the problem", but lack another cable to try this out.
Did you try to turn on Vsync? Usually fixes a lot of problems with dual GPU setups (micro stuttering, screen tearing). Locks your FPS to monitor refresh rate though.
edit: and yeah I also remember that Catalyst A.I. on enabled is required for CrossfireX to work.
The cat only cares when it's feeding time.
I prefer my fps being above refresh rate of my monitor, so I avoid enabling Vsync.
