I have a few questions for you guys...because one of three hard drives that I purchased just over 3 years ago is failing. I'm worried about the other two now. They're all out of warranty.
What value do you set for "Tasks checkpoint to disk at most every XX seconds" in BOINC -> advanced -> preferences -> disk and memory usage? What I'm getting at is: Does this setting have a lot to do with drive longevity? And if so, what should I set it to in order to ensure a longer drive lifespan?
What brands do you recommend for sata hard drives (not SSD....yet) for crunching, and otherwise? (My crunchers, all 2 of 'em, serve other purposes besides strictly crunching)
Should I even bother with "enterprise class" drives? (twice the $$$ for less than twice the warranty)
Thanks for any suggestions.
