Issue 187, Page 55, May 2010.
I guess this means the embargo on official data is over!
Source: http://www.pcpro.co.uk
Intel i7 920 C0 @ 3.67GHz
ASUS 6T Deluxe
Powercolor 7970 @ 1050/1475
12GB GSkill Ripjaws
Antec 850W TruePower Quattro
50" Full HD PDP
Red Cosmos 1000
Need mag cant get it, UK too far from India need scan asap...
aaaa
Coming Soon
its not the first gulftown review... there have been 1 or 2 a couple of months ago aleady
Those ones were based on ES models and believe me the retail ones are different.
I have heard temp monitor is fixed a bit and also it was better air OC, sadly i did not get a B1 and just had a dam B0.
Coming Soon
The Review Title is: Intel Core i7-980X so while they only show a bottom shot so it looks exactly the same as my or anyone else's ES and is reviewed at the Stock Frequency of 3.33GHz with turbo enabled spinning it up to 3.6GHz.
More than anything else it shows how their testing methods are not really multicore ready since my review system ('High-End PC' sorry chaps this is lower mid-range - i3 530@3.5GHz, page 43) gets 2.05 where this CPU gets 2.23 when realistically it has ~3x the performance.
ASUS 6T Deluxe
12GB GSkill Ripjaws
50" Full HD PDP
Red Cosmos 1000
Review Scan is up
ASUS 6T Deluxe
12GB GSkill Ripjaws
50" Full HD PDP
Red Cosmos 1000
Oh, I wasn't aware that the term "review" can now also be used for "one-page no-info article".
I expect a bit more depth from their CustomPC/Bit-Tech stablemate.
ASUS 6T Deluxe
12GB GSkill Ripjaws
50" Full HD PDP
Red Cosmos 1000
Any way we can get PC pro in the US?
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
The paradox, the first review of the latest *e* is *Print Only*. I thought everybody had stopped cutting trees.
► ASUS P8P67 Deluxe (BIOS 1305)
► 2600K @4.5GHz 1.27v , 1 hour Prime
► Silver Arrow , push/pull
► 2x2GB Crucial 1066MHz CL7 ECC @1600MHz CL9 1.51v
► GTX560 GB OC @910/2400 0.987v
► Crucial C300 v006 64GB OS-disk + F3 1TB + 400MB RAMDisk
► CM Storm Scout + Corsair HX 1000W
► EVGA SR-2 , A50
► 2 x Xeon X5650 @3.86GHz(203x19) 1.20v
► Megahalem + Silver Arrow , push/pull
► 3x2GB Corsair XMS3 1600 CL7 + 3x4GB G.SKILL Trident 1600 CL7 = 18GB @1624 7-8-7-20 1.65v
► XFX GTX 295 @650/1200/1402
► Crucial C300 v006 64GB OS-disk + F3 1TB + 2GB RAMDisk
► SilverStone Fortress FT01 + Corsair AX 1200W
B0's dont clock as good as my A0's did under water. They need more juice, i did note this time around the heat generated seemed lower than before . But cant be sure the temp sensors are way off the A0's had this odd problem and so does the B0's i was told the retail will fix the problem.
Ya apple does make a mean A4
Coming Soon
People don't need high performance cpu's.
Five-sixths of the desktop performance for around one sixth of the price .Priceless
At that level anyone can spit out 3-5 reviews a week... imagine they even get the hardware and do zero with it :p and I have to beg to get a sample and spend days, weeks with it... who's the stupid guy ? it's me :p
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
*article* blah blah blah... stuff we already know.... *end.* I WANT RELEASE DATES!
I just want 32nm, but not 6 cores.
ASUS 6T Deluxe
12GB GSkill Ripjaws
50" Full HD PDP
Red Cosmos 1000
► EVGA SR-2 , A50
