well I was going to get (and MIGHT still get) a "Asetek KT12A-12VX WaterChill Triple 120mm Power CPU/VGA/Chipset Water Cooling Kit" because it looked like a decent kit..
some quick specs on the kit...
-Hardware Labs Black Ice Pro III TRIPLE 120mm Radiator
-(3) Adda AS1212MS-A73GL 80.5 CFM fans
-WaterChill 12V Integrated Pump/Reservoir
10mm (3/8" connector) (03-L-1223) 900 l/hm
-WaterChill Pump System Control Software
-WaterChill Antarctica CPU Cooler (CPU01/A) (03-L-2030)
-about $110
how ever I found that people say the pump has a high fail rate...so I'm thinking again, lol
so I made a custom set up but it's a bit more money than I think I can spend ATM so can you guys look it over and let me know if I can save money/get better stuff for the same price or cheaper?
- Swiftech MCRES Micro Revision 2 reservoir
- Swiftech MCP655™ Series 12 VDC Water Pumps
- Koolance Radiator, 2x120mm, Copper Vert.
- Watercool HEATKILLER® CPU Rev3.0 754/939/AM2 LC CPU Water Block
- 8ft of Koolance Tubing, Black PVC, [ID: 13mm (1/2")
- about $240 shiped
all 1/2" fittings and tubing
do you guys think I should get a Swiftech MCR320-QP Quiet Power 3X120mm or MCR420-QP Quiet Power 4X120mm insted of the koolance one? if I did I would put my 4 110cfm Scythe Slipstream fans on it.... or would I be good with the koolance one?
I only plan to cool my CPU at the moment. hope you guys could help.
