Results 1 to 3 of 3
Thread: Which one will be better ?(T9500@ 3.56GHz VS Q9100 @ 2.35GHz)
    Mar 2006
    Ultra Clean Room
    Question Which one will be better ?(T9500@ 3.56GHz VS Q9100 @ 2.35GHz)
    Hello everyone.
    I have a MSI PM45 mainboard laptop (MSI-GT628)
    and it supports Core 2 Duo/Quad CPU
    I want to upgrade the CPU
    and I have found :
    Q9500 ES QZOR 2.6GHz /6MB
    Q9100 ES QAVK 2.26GHz /12MB
    and they are the same price ($160)
    (after overclocking for 3D gaming and 7Zip compressing)
    (T9500@ 3.56GHz (276x13) VS Q9100 @ 2.35GHz (276x8.5) )
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    the higher clocked one will do better, but for laptops u generally have a fixed power on the board and that goes for the cpu and gpu and most of the time clocking the gpu higher on a dual core cpu at 2.6-2.8 is the best solution
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Mar 2006
    Ultra Clean Room
    finally, I have got the Mobile Q9200 ES ($149)
    and OC to 2.93GHZ for benchmark
    (2.88GHZ for daily use)
