Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Project: Gattaca
    Jul 2007
    Cambridge, UK
    Project: Gattaca
    I am about to embark on a new project, turning and old G5 Apple PowerMac case into a PC, well actually a Mac Pro.
    Parts List:
    Case(s):
    G5 PowerMac Case: (Ebay)
    Donor Case: Coolermaster ATC-201
    Parts: Antec 900
    Components:
    CPU: Intel Q6600 @3ghz
    Motherboard: Asus Blitz Formula SE
    RAM: 4GB Crucial Ballistix
    HDD: Seagate 80GB 7200.9
    GFX: Nvidia 9400GT 512MB
    PSU: X-Power 500w
    DVD/RW: Samsung 20x SATA DVD/RW
    Soundcard: Asus SupremeFX II
    OS:
    Retail OSX 10.6.2 Snow Leopard
    Last night I stripped down the G5 case to a shell and began measuring the back panel for surgery.
    UPDATE: Pics added.
    [SIGPIC][/SIGPIC]
    Jul 2007
    Cambridge, UK
    Chop Shop:
    First thing to do is strip out everything from the case that is getting in the way, a nice blank canvas.
    Use a jigsaw of a Dremel (I prefer a Dremel with a disc cutter) to cut out the hole for the motherboard tray, also remove all the old motherboard stand offs apart from 2 which you will need to fix the new tray to the side panel.
    I am using an aluminium removable tray from a donor case.
    Test fit the tray and make sure it sits square in the case and look for possible fixing options
    Stand back and view your handy work
    Reference shot.
    Another reference shot.
    Shake it baby!
    And one more for good luck.
    [SIGPIC][/SIGPIC]
    Jul 2007
    Cambridge, UK
    Assembly:
    The upper panel of a G5 powermac (when hdd bays and fans are removed) is exactly the right size for mounting the PSU. I used 5 double sided sticky pads on the bottom of the PSU to stick it to the bottom of the panel so it would not slip around. Make sure the power switch is set to "on" and plug in a power cable and route it down the back of the panel.
    Fit a normal DVD drive and make sure there is a power plug ready for it. Route the rest of the power cables / ATX plugs through a convenient hole at the rear of the DVD drive.
    As the cable is routed behind the motherboard tray all you need to do now is re-attach the door latching mechanism and fix back the top tray to the chassis.
    Fix back the clear perspex latch to the top tray and make sure it fits properly. Now the chassis resembles a PC more and rest is pretty much as a normal PC build.
    Drill and fix the motherboard tray to the internal 2 stand offs we left and screw the back panel to the chassis making sure nothing moves around.
    Cut out and fit a chassis plug to the rear panel and fix it in place.
    Wire up the chassis plug to the PSU plug cable and make sure its covered with insulation or a purpose made rubber boot which will stop you getting electrocuted, it is the most dangerous part in the case so pay special attention here!
    I wired the front panel connectors USB/Firewire/Audio/Power button and LED up to several accessory cables I had around which had normal PC fittings to attach to the motherboard, shrink rapped them and covered the bundle in black braiding.
    Fit the motherboard/processor/ram/graphics etc.. and find a good place to fix down a HDD (I used a 3.5" adapter tray from an Antec 900)
    I replaced the Apple rear fan with a MUCH quieter YS-tech 80mm fan which also moved a lot more air.
    Next up is cooling, I used the front fan inserts from an Antec 900 and attached Scythe HDD stabalizer rubber mounts to them and then drilled and fixed them to the perspex cover.
    Braided the fan cables which are nice and long and plugged them into the the motherboard.
    Attached the perspex cover back to the case and forget about cooling problems
    Welcome to the wind tunnel The fans are controlled by the motherboard temperature sensors.
    Case side back on and locked into place.
    Plug it in a test everything works!
    [SIGPIC][/SIGPIC]
    Jan 2010
    Phoenix AZ USA
    wow is only 3 post's and all are from u, funny if u ask me
    CPU 920 Apogee XT
    MOBO asus R3E
    RAM G.Skill ripjaws X 2133 @ 1450 6-6-6-12
    GPU Evga gtx 480 850/1686/1936
    HDD 300GB WD raptor
    PSU TX750 corsair
    RAD black ice GTX Xtreme 360 and 240
    PUMP DDC
    Jul 2007
    Cambridge, UK
    Changed to ATC-201 motherboard tray as the ATC-101 tray did not fit.
    [SIGPIC][/SIGPIC]
    Jul 2007
    Cambridge, UK
    Quote Originally Posted by azcrazy View Post
    <tumble weeds> ...
    [SIGPIC][/SIGPIC]
    Xtremely Hot Sauce
    Sep 2007
    New York
    No really. Without any pictures or sketches, it's really tough to offer any comment. Not even a "nice!" or "looking good!" is possible. Open up with a few pictures of what you have (regardless of progress) and my guess is that you'll start getting comments.
    My toys:
    Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
    Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
    Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
    Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    Well. I can comment without any pics posted only that project name is one of my favourite sci-fi movies of all times. I doubt seeing references to it in mod apart from name though. It's hard to imagine something to do with 50ties' cars or DNA discrimination in case mod .. maybe painted face of Uma Thurman on sidewall?
    One might make something steampunk-ish though .. i recall computers/their keyboards and such in space academy shown as some old style hw.
    Xtreme Enthusiast miptzi's Avatar
    Feb 2008
    Not sure if...
    he was afraid of not having empty topics left, I he waited.....
    Raidmax ATOMIC - Core i7 3770s + Corsair H70 // Gigabyte H77N WIFI // Corsair Vengeance 2x4GB 2133mhz // EVGA GTX1060 ACX2.0// Kingston SUV400 480Gb // Sharkoon SFX500L
    Jul 2007
    Cambridge, UK
    Quote Originally Posted by churchy View Post
    Glad you got the reference
    You will have to wait and see.
    [SIGPIC][/SIGPIC]
    Jul 2007
    Cambridge, UK
    Well I finally got some daylight to use the dremel, pics added.
    [SIGPIC][/SIGPIC]
    Nov 2009
    very nice start.
    Mar 2009
    Irvine,CA
    love the name.
    Xtreme Cable Management Freak
    Dec 2008
    Ontario, Canada
    NOOOOOO YOU BEAT ME TOO IT!!! damn... im getting a Mac Pro case this summer and modding it... oh its on.... its on.....
    Where did you get the case btw?
    then again i am building a WC loop inside it... lol
    Project: HeadShot
    Intel i7 3770k | Corsair H100
    EVGA GTX-590 Classified | XSPC GTX 590 Waterblock
    Gigabyte G1.Sniper 2 MotherBoard | Swiftech MCR-320 Res/Rad/Pump
    16GB Corsair Vengeance Low Profile Ram
    Crucial M4 128GB / Intel X25-M 160GB / WD 1TB Black
    Corsair AX850W PSU
    27" Apple Cinema Display (2560x1440)
    Corsair 600t White
    You best be Crunching and Folding/GPUgrid'ing!
    Jul 2007
    Cambridge, UK
    You snooze you lose :P
    Technically its a totally different mod as the Mac Pro is pretty much a MicroATX pc.
    The G5's are a lot more PowerPC so need to be stripped and chopped.
    The case was from Ebay, I picked it up for £60 as it was sold as stripped.
    I am now planning how I can best fit my watercooling gear and also hard drives.
    [SIGPIC][/SIGPIC]
    Dec 2008
    Ontario, Canada
    Quote Originally Posted by Ch3ck5um View Post
    should be a good one! cant wait to see what you do!
    Project: HeadShot
    Corsair AX850W PSU
    Corsair 600t White
    Jul 2007
    Cambridge, UK
    Another small update for assembly.
    DVD and PSU installed
    [SIGPIC][/SIGPIC]
  18. #18
    Jan 2009
    Where from did you get your back panel for your case?
  19. #19
    Jul 2007
    Cambridge, UK
    Quote Originally Posted by faraprejudecati View Post
    The rear panel and tray is from an old Coolermaster ATC-201.
    The same back panel and tray is also in the Coolermaster Wavemaster case, I know this as I have just coverted a wavemaster into a ATC-201 using the spare parts from the old ATC-201 donor case.
    [SIGPIC][/SIGPIC]
  20. #20
    Feb 2005
    Estonia/Tallinn
    Seems like a good project , keep us updated
  21. #21
    Xtreme Mentor
    Aug 2008
    Australia
    Nice this is different, good progress so far. Keen to see how it turns out.
  22. #22
    Nov 2009
    Portugal
    Love those macbook cases , wish i could get one !
    More...
  23. #23
    Jul 2007
    Cambridge, UK
    Added pics to Assembly:
    Fitted PSU chassis plug.
    Fitted Apple triple blade 80mm delta fan.
    Removed lug from rear panel.
    [SIGPIC][/SIGPIC]
  24. #24
    Jul 2007
    Cambridge, UK
    Next up is the hard drive mounting options although I am a little stumped ...
    Ideas anyone?
    [SIGPIC][/SIGPIC]
  25. #25
    Dec 2008
    Ontario, Canada
    Ideas anyone?
    if you can get a silverstone tj07's hard drive mounting cage you can always attatch that to the base of the case.. same deal with any holders really.. Thats one of the reasons why id like to get the mac pro case rather than the g5, due to its hard drive sleds.
    Project: HeadShot
    Corsair AX850W PSU
    Corsair 600t White
