Due to another thread I started I know I have to refresh coolant soon. I could state this question in that thread as well but the title would be misleading. Therefore I started a new one.
At this moment I use Tygon R-3603 7/16" ID and 10/16" OD with Fesser One Red coolant. Due to answers in my previous thread, other threads around this board and my own experience I started to doubt this setup.
Tubing
Actually I want to get rid of the Tygon because of clouding and want a good replacement. However I'm stuck with 7/16" ID because 3/8" ID is hard to fit on my MCP pump with 1/2" barbs. I also doubt if I want colored tubing because my system is hard to bleed and with colored tubing I can't see where air in the tubes is still located. Moreover I'm stuck with a few brands of 7/16" ID tubing my retail shop sells (Masterkleer, Tygon and XSPC). It's a pity Primochill doesn't sell 7/16" ID tubing.
Should I get XSPC tubing as a substitute for Tygon R-3603 with regard to clouding and bending?
Coolant
Furthermore I'm not sure if I'm happy with this premix coolant. I hear and read several horor stories about these premix coolants. At this moment my loop is still running and therefore I don't know if my components are also afected by gunk. I really like it when the tubes look colored. Unfortunately I think I can't use colored tubing due to my system that is hard to bleed.
I heard that it is best and cheapest to simply use distilled with PT Nuke. Although it's hard for me to imagine how it would look like, functionality is my priority. Therefore I have the following questions:
1) How much PT Nuke should be mixed with distilled?
2) Would XSPC tubing be affected by the mixture of distilled and PT Nuke? Or would it be least affected due to less additives in the coolant?
I want the tubing and coolant to be clear over time. Thanks for taking the time in answering my questions.
