Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Thread: Chile earthquake shifted Earth's axis
    Apr 2008
    Post Chile earthquake shifted Earth's axis
    The massive 8.8 earthquake that struck Chile may have changed the entire Earth's rotation and shortened the length of days on our planet, a NASA scientist said Monday.
    The quake, the seventh strongest earthquake in recorded history, hit Chile Saturday and should have shortened the length of an Earth day by 1.26 microseconds (millionths of a second), according to research scientist Richard Gross at NASA's Jet Propulsion Laboratory in Pasadena, Calif.
    "Perhaps more impressive is how much the quake shifted Earth's axis," NASA officials said in a Monday update.
    The computer model used by Gross and his colleagues to determine the effects of the Chile earthquake effect also found that it should have moved Earth's figure axis by about 3 inches (8 centimeters or 2.7 milliarcseconds).
    Earth's figure axis is not the same as its north-south axis, which it spins around once every day at a speed of about 1,000 mph (1,604 kilometers per hour).
    The figure axis is the axis around which Earth's mass is balanced. It is offset from the Earth's north-south axis by about 33 feet (10 meters).
    Strong earthquakes have altered Earth's days and its axis in the past. The magnitude-9.1 Sumatran earthquake in 2004, which set off a deadly tsunami, should have shortened Earth's days by 6.8 microseconds and shifted its axis by about 2.76 inches (7 centimeters, or 2.32 milliarcseconds).
    One Earth day is about 24 hours long. Over the course of a year, the length of a day normally changes gradually by one millisecond. It increases in the winter, when Earth rotates more slowly, and decreases in the summer, Gross has said in the past.
    The Chile earthquake was much smaller than the Sumatran temblor, but its effects on Earth's figure axis were a bit larger because of its location. Its epicenter was located in the Earth's mid-latitudes rather than near the equator like the Sumatran event.
    The fault responsible for the 2010 Chile quake also slices through Earth at a steeper angle than the Sumatran quake's fault, NASA scientists said.
    "This makes the Chile fault more effective in moving Earth's mass vertically and hence more effective in shifting Earth's figure axis," NASA officials said.
    Gross said his findings are based on early data available on the Chile earthquake. As more information about its characteristics are revealed, his prediction of its effects will likely change.
    The Chile earthquake has killed more than 700 people and caused widespread devastation in the South American country.
    Several major telescopes in Chile's Atacama Desert have escaped damage, according to the European Southern Observatory, which manages those facilities.
    A salt-measuring NASA satellite instrument destined to be installed on an Argentinean satellite was also undamaged in the earthquake, JPL officials said.
    The Aquarius instrument was in the city of Bariloche, Argentina, where it is being installed in the Satelite de Aplicaciones Cientificas (SAC-D) satellite. The satellite integration facility is about 365 miles (588 km) from the Chile quake's epicenter.
    The Aquarius instrument is designed to provide monthly global maps of the ocean's salt concentration in order to track current circulation and its role in climate change.
    An earlier version of this report misstated the length by which Earth's day was expected to be shortened, as well as the amount of movement in Earth's figure axis.
    Chile earthquake may have shortened days - Space.com- msnbc.com
    Seventh strongest quake in recorded history have shifted Earth's axis
    2012
    Feb 2008
    Russia
    NASA will inform us soon. But maybe will not.
    Intel Q9650 @500x9MHz/1,3V
    Asus Maximus II Formula @Performance Level=7
    OCZ OCZ2B1200LV4GK 4x2GB @1200MHz/5-5-5-15/1,8V
    OCZ SSD Vertex 3 120Gb
    Seagate RAID0 2x ST1000DM003
    XFX HD7970 3GB @1111MHz
    Thermaltake Xaser VI BWS
    Seasonic Platinum SS-1000XP
    M-Audio Audiophile 192
    LG W2486L
    Liquid Cooling System :
    ThermoChill PA120.3 + Coolgate 4x120
    Swiftech Apogee XT, Swiftech MCW-NBMAX Northbridge
    Watercool HeatKiller GPU-X3 79X0 Ni-Bl + HeatKiller GPU Backplate 79X0
    Laing 12V DDC-1Plus with XSPC Laing DDC Reservoir Top
    3x Scythe S-FLEX "F", 4x Scythe Gentle Typhoon "15", Scythe Kaze Master Ace 5,25''
    Apple MacBook Pro 17` Early 2011:
    CPU: Sandy Bridge Intel Core i7 2720QM
    RAM: Crucial 2x4GB DDR3 1333
    SSD: Samsung 840 Pro 256 GB SSD
    HDD: ADATA Nobility NH13 1GB White
    OS: Mac OS X Mavericks
    Sep 2004
    Yeah, not a big deal. Lets wait till the 2012 advocates get in on this action. Sensationalism!
    Xtreme Cruncher
    Jan 2005
    England
    well i can't say that ill be losing any sleep over that 'MASSIVE' day shortening
    My Free-DC Stats
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    Jun 2007
    so, if the lower hemisphere days are shorten, then the upper hemisphere is gonna take the lengthy light hours
    Xtreme Cruncher
    Jul 2003
    Finland, Eura
    This was fun indeed, micro seconds....
    http://mato78.com - Finnish PC Hardware news & reviews
    BulldogPO @ Twitter
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by BulldogPO View Post
    Haha, yeah... Hell, not even a minute shorter...
    Donate to XS forums
    Nov 2005
    Pamplona, SPAIN
    And this came out because of the movie 2012, because in 2004 we never heard about it.
    Talk about priorities, NASA...
    i7 2600k @4500 | Gigabyte GA-Z68X-UD4-B3 | Gskill 2x4096Mb 2133Mhz | 4x2TB WD Green RAID10 | OCZ Vertex3 120Gb | 2x AMD 6950 @ Stock
    Benq 24" TN | Samsung LE46C630 "2nd" Monitor | Enermax NAXN ENP850EWT | Corsair 800D Case | Corsair H60 | Logitech G9x + Wireless Solar K750
    Feb 2008
    Russia
    hmmm, guys...nothing funny is here... do you know about materics move from each other for about 5cm per year? 1 milion years x 5 cm = 50 kilometres. A big deal here.
    LG W2486L
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by WaterFlex View Post
    We don't know if human civilization is going to last another 100 years, and you're talking about 1,000,000. You know, in 1M years something happening to one particular planet will likely be not a big deal.
    Donate to XS forums
    Xtreme Cruncher
    Jan 2008
    Finland
    1.26ms
    Intel i7 2600k, Asus p8p67 EVO, Thermalright Archon, G.Skill RipjawsX 8GB, Asus EAH6970 DCII, Corsair AX850W, Asus xonar essence ST, Coolermaster HAF 932,
    Crucial C300 128GB, WD Caviar Black 1 TB, Samsung F3 1TB.
    The world needs your support.
    Join The XS WCG team and help cure Cancer, AIDS, and other diseases.
    Apr 2008
    Stockholm, Sweden
    1.26 microseconds = 1.26µs = 0.00126ms.
    Apr 2008
    Texas
    Quote Originally Posted by Reznik Akime View Post
    The frequency of earthquakes seems to be rising as of late. EDGAR CAYCE WAS RIGHT! (The sensationalism has begun, but probably true).
    Core i7 2600K@4.6Ghz| 16GB G.Skill@2133Mhz 9-11-10-28-38 1.65v| ASUS P8Z77-V PRO | Corsair 750i PSU | ASUS GTX 980 OC | Xonar DSX | Samsung 840 Pro 128GB |A bunch of HDDs and terabytes | Oculus Rift w/ touch | ASUS 24" 144Hz G-sync monitor
    Quote Originally Posted by phelan1777 View Post
    Hail fellow warrior albeit a surat Mercenary. I Hail to you from the Clans, Ghost Bear that is (Yes freebirth we still do and shall always view mercenaries with great disdain!) I have long been an honorable warrior of the mighty Warden Clan Ghost Bear the honorable Bekker surname. I salute your tenacity to show your freebirth sibkin their ignorance!
    xtreme energy
    Oct 2004
    Europe, Latvia
    Quote Originally Posted by zalbard View Post
    It will last, wanna bet?
    Jul 2008
    Quote Originally Posted by kiwi View Post
    Oil's gone in 40, for sure. After that happens I have nooooo idea!
    Asus P6T SE || 965 XE @ 4.0GHz [currently OCing]|| OCz DDR3 Plat 3x2Gb 1600 7-7-7-20
    2x Sapphire HD4850 CrossfireX || WD VelociRaptor 300GB || Antec Quattro 1kW PSU
    Cooling:
    D-Tek FuZion v2 || Swiftech MCR320 || MCP355 w\ XSPC Res Top || Scythe S-Flexes
    Aug 2009
    Quote Originally Posted by Zigosity View Post
    Nuclear power is future.....
    Dec 2002
    well if the stuff is moving, some cities are in danger.
    4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11 (one of the 26% that isnt confused on xtreme forums)
  18. #18
    Sep 2008
    Poland/London
    Quote Originally Posted by mindfury View Post
    Iron Man battery>all
  19. #19
    Banned
    Sep 2009
    Fermi will shift earth axis and north-south axis, and because of that, we will be out from some big bad comet trajectory, somewhere in the near future.
    Sorry had to do it, the fun it's almost over...
  20. #20
    Jan 2008
    Awaiting the day when California becomes an island. We're are so long over due according to my old Geology Prof.
  21. #21
    Jul 2007
    Kuwait
    dude kuwait reserve of oil will last a 100 years at lest i can assure you that
  22. #22
    Nov 2007
    Cincinnati, Ohio
    Who cares if the axis moves. I mean in 2012 the poles flipped while they were flying and they only crashed a few kilometers from where they thought they were going. Not bad considering they should have been on the other side of the equator.
    So, this is why people are living longer. Back in the 1800's the years were so much longer. A couple more earthquakes and I should be able to make it to at least 175 years old.
    Aaron___________________________Wife________________________ HTPC
    intel i7 2600k_____________________AMD5000+ BE @ 3ghz___________AMD4850+ BE @ 2.5ghz
    stock cooling______________________CM Vortex P912_______________ Foxconn A7GM-S 780G
    AsRock Extreme 4_________________ GB GA-MA78GM-S2H 780G_______OCZ SLI 2gb PC6400
    4gb 1600 DDR3___________________ OCZ Plat 2GB PC6400___________Avermedia A180 HDTV tuner
    MSI 48901gb 950/999______________Tt Toughpower 600w___________ Saphire 4830
    Corsair HX620____________________ inwin allure case___________ ___ Coolmax 480w
    NZXT 410 Gunmetal________________Acer 23" 1080p________________ LiteOn BD player
    X2gen 22" WS
    ________________ ________________________________ nMediaPC 1000B case
  23. #23
    I am Xtreme
    Dec 2008
    France
    *Reaches his black suitcase with a red button* Muhahaha!
    Quote Originally Posted by Power5 View Post
    A couple more trillions of earthquakes and I should be able to make it to at least 175 years old.
    Fixed!
    Donate to XS forums
  24. #24
    Feb 2009
    Montreal
    Sarcasm
    some more virtual distance...
    your head
    Carry on.
    Quote Originally Posted by Mechromancer View Post
    I think it has more to do with the news cycle. It's like the yearly [insert animal name] Flu scare. Fear sells, pictures of people in distress sells. Media moguls know it and they capitalize on it.
    I'd like to see a frequency analysis of earthquakes to really be able to back my point of view though :P
  25. #25
    Dec 2005
    Northern Virginia
    All these strong earthquakes do make me wonder about how much pressure may be building up inside the planet. I'm no expert, but aren't earthquakes and vulcanism related? I know scientists have been keeping a close eye on certain volcanoes that have been spewing, not quite erupting yet. Plates shift, increasing pressure inside the earth...just a not-so educated theory. Any validity to this?
    Computer:
    Case: Corsair 750D Airflow Edition
    Mobo: Gigabyte Aorus X570 Ultra
    RAM: Team TForce Xtreem ARGB 3600C14 2x16gb XMP
    CPU: AMD Ryzen 5900x
    Graphics: EVGA (rip) RTX 3080 FTW3
    PSU: Seasonic Focus GX 850w
    Cooling: Arctic Liquid Freezer II 360mm
    NVMe: SKHynix P41 Platinum, Samsung 980 Pro 2tb
    SSD: Micron 1100 2TB, Samsung 860 Evo 1tb
    HDD: WD SE 2TB, WD Black 1tb 3 platter with over 10 years of power-on time
