Curious what everyone would get in this situation... or if there's anything out there THAT much better, yet. Any comments or opinions are appreciated!
I've had a Vaio T250 "netbook" for around 5 years now. It's been a GREAT laptop, but it is starting to show its age. Namely, the 1GB max memory combined with a 1.8" SLOOOOOWWW hard drive (with IDE interface) and deteriorating battery. Down to around 1.5hr with light usage now. (Used to be around 5hrs.) Can't even answer a Skype call on the first try. If you don't catch it immediately, the lag from the HD is so bad, you miss the call in skype.
Anyway....
How does the Atom compare to the 1.2Ghz ULV 753 Dothan (Pentium M)? I've heard the Atom has to be significantly faster in speed to be equal in performance... any truth to that? Should I go for a Z or an N Atom? Not really understanding the difference there.
I don't know if I'm being too demanding for a netbook, but it doesn't seem to hard to put these specs together in one package:
- 10-11" lcd backlit screen higher than 1024 rez. 1366 would be nice. (T250 is 1280x768 @ 10.6")
- at leats 2GB memory (or upgradeable to)
- SSD (or at least be able to swap a nice one in myself. so, sata-II needed?)
- Win7 (any version, can upgrade later if need be)
- LOTS of battery... 6hrs and up. 10+ would be sweet.
- 3 lbs or less... and thin if possible. The one thing thats been annoying about the T250 is the way the battery sticks off the back. Totally blows the look and feel of it, making it seem clunky.
- The icing on the cake would be LIT KEYS!! Using full size laptops with those, I'm addicted. Absolutely love those.
Has anyone seen the new Sony X series? They seem nice, but the price tag is a little ridiculous, and not really "netbook" territory. (Though, on paper, it's pretty serious.)
2Ghz Z550, 2GB mem, 11.1 screen (1333x768), 14hrs battery (12@max brightness), 64GB SSD, 1.6lbs, .5" thick, win7 home prem. wifi-n, built-in gps, 2 batteries (3.5hr + 14hr extended)
http://www.sonystyle.com/webapp/wcs/...specifications
