Now that i have your attention,
Im trying to find a fan controller, one with 6 or 7 controls, has a display for fan speeds, and has one display for a temperature. Maybe even presets for "silent" "gaming" or "Max"
Does this thing of beauty exist?!
Project: HeadShot
Intel i7 3770k | Corsair H100
EVGA GTX-590 Classified | XSPC GTX 590 Waterblock
Gigabyte G1.Sniper 2 MotherBoard | Swiftech MCR-320 Res/Rad/Pump
16GB Corsair Vengeance Low Profile Ram
Crucial M4 128GB / Intel X25-M 160GB / WD 1TB Black
Corsair AX850W PSU
27" Apple Cinema Display (2560x1440)
Corsair 600t White
You best be Crunching and Folding/GPUgrid'ing!
just buy 2 of these. Each one controls 5 fans.
http://www.nzxt.com/series/fan_control_panels/
Lamptron FC-5
I own 2 and i LOVE them.
BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
Project: HeadShot
Corsair AX850W PSU
Corsair 600t White
Forget those and get the Koolance controller board with expansion. It will do 6 fans, 2 pumps and a crap load of temp sensors and has a display on your desktop. I love it.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
Project: HeadShot
Corsair AX850W PSU
Corsair 600t White
Nope, not for a post header like that. We are a bit more tainted to approve of such weak headers or a bump ask in less than 24 hours.
All stock for now, no need for more, but it's gonna be soon methinks.
Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
SLI GTX470 EVGA
EK HF nickle blue top CPU block (free from Eddie)
Koolance 470 waterblocks
One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
Banchetto Tech Station
120 GB SSD, and a few other drives.
1000W UltraX3 PSU, 900 watt (1500VA UPS
23.999" Acer GD235hz and 24" Acer H243H
Project: HeadShot
Corsair AX850W PSU
Corsair 600t White
Desk Build
W/C System
Circles SucQ!
Try to source for an old school DigiDoc 5. It thermally controls up to 8 fans and displays 8 temps and voltage readings. Just sold mine after upgrading to a Matrix Orbital GX Typhoon.
Here's one on Ebay -> http://cgi.ebay.com/MacPower-DigiDoc...24135002r18473
Phil
Um, Yes it does.
http://www.performance-pcs.com/catal...ducts_id=26486Features:
* CNC milled from blocks of 3/4" thick solid aluminum
* Bring out that full aesthetic appeal you always wanted in the 5.25 inch bay
* Four knobs to control four 3pin channels
* User's choice of displaying Celsius, Fahrenheit, or Voltages for the bottom line readout
Circles SucQ!
Project: HeadShot
Corsair AX850W PSU
Corsair 600t White
I think it works great. If it had an external display that would be great, but otherwise I don't think I could ask for more. The only thing is that it only works with Koolance temp fittings. It comes with temp probes, but if you want one to measure your water temp you will need to use the Koolance ones.
Desk Build
W/C System
Latest version software lets you set a delta for each temp probe. You'll need to do a bit of legwork beforehand (find out how much is the difference between actual temp and XXX temp probe + TMS200 reported temps), but after that you can use any temp probe you wish.
Sorta on topic...
-Disingenuous topic is kinda irritating. If you're telling us to not take your posts seriously in the future then...well done I guess?
-"Linky for the lazy bum?"...also kinda irritating.
C'mon you've posted here enough to know your way around the forums. There are many topics on fan controllers, a search would turn up plenty of results.
right, so now this controller actually is dead.. and now i need a new one.. if anyone knows of someone selling a good used one, or you yourselves, let me know (i know this is against forum policy im sorry its relevant to the thread)
Project: HeadShot
Corsair AX850W PSU
Corsair 600t White
What died? The fan controller you have?
Desk Build
W/C System
Project: HeadShot
Corsair AX850W PSU
Corsair 600t White
I actually just installed a sunbeam rheobus extreme in my machine today to replace my Lamptron FC-2, and I'm a lot happier with it. FC2 just caused too much trouble with the squealing.
Mountain Mods U2 UFO
Intel i7 965 EE
EVGA Classified
6GB Corsair Dominator GT cas 7 2000MHz
2x EVGA 295 GTX SLI
Hauppauge WinTV 2250
Auzentech X-Fi Forte 7.1
1x 80GB Intel X25M SSD, 2x 1TB WD Caviar Black RAID 1
Corsair HX1000
HK 3.0 Block, Bitspower Chipset/Mosfet
360 + 240 Feser Radiators
2x MCP 355 w/ XSPC Reservoir Top
The only thing I first noticed about the lamptron FC5 is that it needs an adjustable contrast.
I haven't played with it much yet, just a quick trial.
I like the idea of the Koolance controller, would be nice to be able to add a display as well. EDIT: fan controller section can only support 2A per ch I guess most could manage with that, approx 4 fans/ch depending on fans
EDIT: Aquaero 4.0, but I do not think you can find it in the US
