+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 38
Thread: Antec 600 / 902 case mod for PAX East 2010
    Xtreme Member Bill Owen's Avatar
    Jul 2009
    Mnpctech.com
    0
    Close examination of Antec's newest gaming case before it goes into my hands, Antec Six Hundred case review
    New top grill design concept..
    Top grill design concept..image 2 finished
    Left side side panel cover design for Antec 902, this will be for 2nd case Antec is auctioning off.
    We finished the new vented top piece to replace the Antec 600's "moonroof"
    goodbye Plexi window...hehe
    Updated 2/26: Top plate for the 902, the recessed portions will be painted Black
    Triple 120 intake was to be based off our 120mm Nautilus Fan Grill
    Jul 2009
    Mnpctech.com
    0
    I'll be installing 3 of these 120mm Turbine Fans ...2000 rpm, 79.4 cfm @ 30 dBA
    Along with the shipment of the case, I included....
    http://www.mnpctech.com/ATX_Molex_Removal_Tools.html
    Xtreme Member Soul_train's Avatar
    Nov 2009
    Portugal
    0
    Nice start Bill i'm looking forward too see more from this project!
    Cumpz
    @k@
    Carlos
    Jul 2009
    Mnpctech.com
    0
    Thank you carlos!
    Fitting the new triple turbine intake onto the Antec 600.
    Updated 3/16/10, Final photos
    I got swamped, so I didn't have much time for taking photos before shipping it out. I still need to edit the 902 photos too!
    The exterior finish is a custom mix of Silver Metallic and Gloss Black PPG automotive paint. I absolutely love how this color came out. I would consider painting a car this color... We imagined it on a `68 - `72, Chevelle, Malibu, Nova, or GTO. This case mod was inspired by my love for Hot Rods if you couldn't tell...lol :cooldude:
    360 Turbine style front intake was made from 3/4" thick aluminum. The design was inspired by the "Nautilus" Overkill 120mm fan grill.
    Each of the 120mm Turbine Fans is 2000 rpm, 79.4 cfm @ 30 dBA.
    The vented side panel was cnc milled from 3/16" thick billet aluminum. "Antec - Believe it" logo is engraved in the surface.
    The Antec 600's smoked acrylic moon-roof was replaced by this vented billet panel.
    The honeycomb grill was also custom painted. A remote 3-speed switch is mounted in the rear of the chassis that lets you balance the 200mm fan's performance. You can also switch off the Blue LEDs.
    120mm Turbine fan's chrome plated prop-spinners.
    Xtreme Addict Alexandr0s's Avatar
    Nov 2009
    Netherlands
    53
    Those turbine fans looks great Bill! .
    Xtreme Member individual's Avatar
    Oct 2009
    1
    You never cease to amaze me bill. Love your designs
    Jul 2009
    Mnpctech.com
    0
    Thanks guys! Glad you like it so far
    Xtreme Enthusiast snoro's Avatar
    Nov 2009
    Lévis,Québec,Canada
    0
    So i see you are trying to compete with Darthbeavis for the most blinged out case ???
    It is not my type of case but the quality is superb.
    Quote Originally Posted by DDtung
    We overclock and crunch you to the ground
    May 2004
    0
    Major props! Keep up the good work
    Desktop:
    Antec 300
    Foxcon A7AD-S 790GX
    8GB Gskill PC-1066@5/5/5/12
    PII X940 BE @3.6GHZ
    Sunbeam Core Contact
    2x 640GB in Raid 0+1
    4870 512MB@800/1000
    Vista Business 64bit W/ SP1
    Jul 2009
    Mnpctech.com
    0
    Thanks for comments guys The billet intake resides inside the stock bezel. I've drilled and tapped the sides of the intake for 8/32 size socket head machine screws.
    Nov 2008
    Tigard, Oregon
    0
    Torx head screws ftw!!
    PDXLan attendee 1,2,3,4,5,6,7,8,9,10,10.5,11,12,12.5,13,14,14.5,15 ,(16),(16.5) - Ad Infinitum
    Heatware is nlancaster - http://heatware.com/eval.php?id=50777
    Jul 2009
    Mnpctech.com
    0
    Ok, time for the 902 to grab the spotlight for awhile. This is House Of Kolor Candy Apple Red.
    The color sample book of the Paint Gods, HOUSE OF KOLOR
    Nov 2008
    Tigard, Oregon
    0
    ooo, purty.
    How much prep did you put into it?
    Registered User transit921's Avatar
    Dec 2009
    nj
    0
    that front panel might be the best front panel i seen yet,those turbine fans look crazy also
    Xtreme Enthusiast Frag Maniac's Avatar
    Nov 2007
    0
    Looks nice as usual Bill, but please tell me you're not going to leave the inside of it looking the way Antec made it? Somehow the 600 seems a drastic departure from the Antec norm. Crazy features like the "moon roof", yet not as good air flow as some of their previous offerings and worse looks in some ways.
    Apr 2008
    0
    Looking good. Any status on "overkill 922"?
    Banned
    Feb 2007
    0
    Looks sweet! Love the paint and the turbofans.
  18. #18
    Jul 2009
    Mnpctech.com
    0
    @ nlancaster, a lot, but not nearly as much to paint a corsair 800D chassis..lol, sorry thats been consuming all of our time lately.
    @ transit921, thank you
    @ Frag Maniac, Yes, this has been asked by somebody else and plan to IF I have the time.
    @ bikebuilderdude, will post new updates after these 2 are finished. that case needs to be finished soon, going to Stompfest LAN event for grand prize, http://www.stompfest.com/index.php?pageid=lanreg
    @ Darth, thanks bro
    More photos of the Candy Apple Red 902
  19. #19
    Jul 2009
    Mnpctech.com
    0
    After clearcoaitng the machined aluminum top for the Antec 902. We masked everything, but the 4, recessed sections.
  20. #20
    Jul 2009
    Mnpctech.com
    0
    Photos of the Antec 600 panels and front bezel a few hours after clear coating. I really love this color. It will be great contrast to the machined aluminum features we created!
  21. #21
    Oct 2005
    Bochum / Germany
    0
    Looking really good so far, can't wait for the finished project!!!
  22. #22
    Jul 2009
    Mnpctech.com
    0
    Quote Originally Posted by GrossmeisterB View Post
    Thank you for the nice comment! I will post another update soon
  23. #23
    Xtreme Enthusiast miptzi's Avatar
    Feb 2008
    Not sure if...
    2
    oh man, thisi is completely AWESOME!!!!!!!!!
    watching closely...
    Node 304 - Core i5 3330 // Gigabyte Z77N WIFI // Corsair Vengeance 2x2GB 2000mhz // MSI GTX660ti Power Edition// Corsair NOVA 128GB // Corsair HX650
    Diablo 3 TAG - Miptzi#1384
  24. #24
    Jul 2009
    Mnpctech.com
    0
    Quote Originally Posted by miptzi View Post
    watching closely...
    Thank you for commenting and tuning in miptzi!
  25. #25
    Registered User maximmax's Avatar
    Jan 2010
    Puerto Rico
    0
    This looks great but:
    only 3 3-1/4" drives...why not increase the drive cage to 4, and put another one right next to it for 8 possible drives.
    would the side panels be vented on both sides?
+ Reply to Thread
