Results 1 to 7 of 7
Thread: # of Threads on Fitting
    Apr 2006
    Middle of Nowhere
    So I was looking into a box of old watercooling parts and I came upon a fitting from my old Maze 4 block.
    I saw that it had 4 full threads on it whereas newer fittings have less.
    This got me wondering. Do newer blocks like the Apogee XT have fewer threads in them or have fitting manufactures decided that 2 threads are enough to properly connect a fitting to a component?
    __________________
    Budgets, Bling, We Need Not These. We Have Science!
    Nov 2009
    Netherlands
    The shorter threads work properly, since they're only there to connect the fitting to a certain part. The actual sealing is done by the o-ring.
    The fitting with more threads might have trouble with thinner blocks, which allow fewer threads. Most well known example are the EK FC blocks. If the fitting has too much threads, it will hamper the flow through the block.
    Apr 2006
    Middle of Nowhere
    I understand that the seal is made by the o-ring. I'm just wondering if it is easier to over-tightening and strip the block using fittings with shorter threads?
    __________________
    Nov 2004
    Of course.
    Crunching For The Points! NKrader's Avatar
    Dec 2005
    Vancouver WA, USA
    Quote Originally Posted by AllAgainstPaul View Post
    try it
    Catfood Shotgun
    Motherboard : Asus Strix z370i | CPU : Intel i7 8700k | Ram : 2x16GB Crucial DDR4 3000 | Heatsink : Noctua NH-U14S
    Storage - Boot: 960 PRO 512GB STEAM: 960 EVO 1TB | PSU : Corsair SFX 600w
    Monitor : Samsung Samsung S34E790C 34" Curved (3440x1440)
    May 2008
    Small small town, MA
    I forget where I read it, but most of Koolance new blocks recommend using Koolance fittings for thread depth purposes. Using improper fittings can lead to junky flow numbers. (And i'm using swifty barbs on a Koolance CPU-340 oops!)
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    IIRC, the actual written standard for BSPP fittings works out to be 2-3 threads. DD Highflows have always used the "American standard" of "bigger is better".
    Circles SucQ!
