DISCLAIMER: In light of recent hystericalism and apparent confusion about what this method actually is and does I'm rewriting this first post. This method is for BETA copies of Win 7. It uses legal means by way of administrative control to allow users / small / medium businesses to safely backup their data prior to moving to a retail copy of Win 7. If a mod feels this borders too close to a "crack" or "warez" then feel free to delete this thread.
What is this method?
As described in the disclaimer this is NOT a "crack" or "warez", it is a means for users and small / medium businesses running a beta version of Win 7 to safely backup their data without fear of losing anything due to W7 deactivating and shutting down every 2 hours.
What does this method do?
This method uses Administrative Privilages (read: NOT a crack or warez) to delete a few files, thus preventing beta copies of W7 from shutting down allowing users to safely backup their data without fear of data loss.
How does this method work?
This method incorporates the use of a small (legitimate) registry entry commonly known as Grant Admin Full Control. The purpose in Grant Admin Full Control is to easily take control and access passworded files and folders a user or business may have ported from a older OS to W7. The details about GAFT can be found on mydigitallife at this LINK
So how do I use this method?
You can use this method by following these simple steps;
1. Download a small registry patch called Grant Admin Full Control, simply double-click it and let it add to the registry.
2. Restart your computer and boot into safe mode (press F8 during boot)
3. Search for and delete all files with the following names;
Note: Before you can delete the below files you will need to right-click on each of them individually and then left-click on "Grant Admin Full Control"
SLLUA.exe
sppsvc.exe
SLUI.exe
sppuinotify.dll
SLUINotify.dll
4. Delete any old restore points and empty your recycle bin.
5. Thats it. Your now free to take as much time as you need to backup your data without Windows shutting down every 2 hours.
Hopefully this rewritten post now clears up and clarifies any misdemeanours. Again, if any mod feels this is too much like a crack or warez feel free to just delete the thread.
