Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Saphire 5870 Vapor-X
    Jun 2005
    Massachusetts
    I'm interested in hearing from users of this card and their experiences with its performance. I'm currently running 2-GTX 260's in SLI and the performance is good. However, I'm getting tired of hearing the fans when I clock the cards up for performance. I don't want to water cool the cards. Not worth the expense at this time for these cards.
    The VaporX is a non-reference design with some sort of copper heatpipe cooler. It looks like Saphire may have also upgraded MOSFETs, capacitors, etc. The card is shorter than reference designs.
    Questions:
    Can the gpu voltage be tweaked with MSI Afterburner?
    How loud is the fan? When running it overclocked with fan >65%, does it sound like a hair dryer? Does the fan need to even go that high at higher clock states?
    Performance - I can run Crysis at high settings with V-sync, forcing triple buffering and run 30-60 fps, ave=45 fps @ 1920x1200, with the 191.07 drivers, W-7 Pro 64 bit
    Crysis Warhead runs 30-60 fps, ave=40 fps, no V-sync, enthusiast settings, running 64 bit game .exe, 1920x1200 on the 196.34 drivers. These drivers seem a little borked regarding V-sync and triple buffering. I'm running W-7 Pro 64 bit.
    How would the 5870 compare? My expectations would be a simpler one card set-up, cooler, quieter, preferrably more performance @ 1920x1200 than my current cards. Later I can always add another 5870 or get whatever is performing better as a single card solution.
    Thanks ahead!!
    Asrock Extreme 4 | 2600K | 16G G Skill | Powercolor LCS 7970 | PCP&C 910 Silencer | Crucial C300 + Intel X-25V + Raptors | D-Tek Fusion v2 | Swiftech MCR Drive 360 | HP LP2475
    Jun 2008
    Quote Originally Posted by Sailindawg View Post
    I can answer this one -- can't answer the others tho, sorry, as I have only had watercooled cards for the past ~5 years -- yes, you can voltmod the 5870 via software (Afterburner works good). I believe RBE will let you change it in the BIOS now also.
    ASRock 990FX Extreme4
    AMD FX 8350
    Kingston 16GB (4GBx4) DDR3 1333
    Gigabyte NVidia GTX 680 2GB
    Silverstone 1000W PSU
    PI in the face
    Nov 2008
    Fan is not loud at all, its like a 80mm. They are great cards and run super cool even the top card in a crossfire config. Only thing I would recommend it pointing a fan at the backside of the card, drops temps alot as these dont come with a backplate like reference.
    1000/1300 was stable at 1.187 though
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
    I am Xtreme
    Dec 2008
    France
    The cards have great coolers, indeed, the PCB is the same for all 5870s atm.
    I'd say it's worth getting this one over a 'standard' 5870 if you are not going to watercool.
    Donate to XS forums
    Feb 2009
    Lima, Peru
    Since I know of it's existance I prefer the HD5870 PCS+ from Powercolor. Whisper quiet at idle and whipers quiet at load.
    http://www.techpowerup.com/reviews/P...CS_Plus/1.html
    90mm fan helps
    Athlon II X4 620 2.6Ghz @1.1125v | Foxconn A7DA-S (790GX) | 2x2GB OCZ Platinum DDR2 1066
    | Gigabyte HD4770 | Seagate 7200.12 3x1TB | Samsung F4 HD204UI 2x2TB | LG H10N | OCZ StealthXStream 500w| Coolermaster Hyper 212+ | Compaq MV740 17"
    Stock HSF: 18°C idle / 37°C load (15°C ambient)
    Hyper 212+: 16°C idle / 29°C load (15°C ambient)
    Why AMD Radeon rumors/leaks "are not always accurate"
    Reality check
    Jul 2008
    Germany, Stuttgart
    Quote Originally Posted by Razrback16 View Post
    Careful man!
    The second edition isn't able to be overclocked by MSI Afterburner because of it analog VRM
    Dec 2008
    That HD5870 PCS+ looks super-sexy. Time to wait for them to come in price before I snag one =D
    Jan 2006
    New Hampshire (USA)
    I will post back as soon as possible as my Saphire VaporX 5870 just got delivered a few hours ago (got it from the egg when they were in stock). In about 20min I'm going to install the card and do some basic testing, however this is my first ever AMD/ATI graphics card so I know very little about driver/overclocking software/etc... so it might take me some time to get it sorted? I can say that the card is much smaller than I thought it was going to be, its not much longer than my old GTS250 1GB (a bit shorter than reference design). As someone else already mentioned the VaporX currently available in retail channels (well most retail channels that is) is not capable of voltage adjustment via MSI Afterburner (or any software) because of new VRM design. Unfortunately I've heard first hand accounts from other rev 2 owners that this card doesn't have much overhead in regards to clocks (but I'm really hoping that won't be the case with my card)! Well wish me luck guys and I'll post back later tonight.
    Asus Maximus III Formula (2001)
    Intel i7 860 (L924B516)
    Noctua D14
    Corsairs CMG4GX3M2A2000C2 (2 x 2GB) RAM
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    Creative X-Fi Titanium PCI-e
    LG GGC-H20L Blu-Ray
    Toughpower 850w Modular
    GSkill Phoenix Pro SSD 120GB
    HEAT
    Jun 2005
    Massachusetts
    @Roger D25
    Congrats on your new purchase. The card comes out of the box clocked slightly higher. The review from TechPowerUp indicates that 1000 MHz GPU & 1300 MHz mem were easy achievable at stock fan settings. (edit: TPU reviewed the Powercolor heatpipe card, not the Saphire VaporX - both cards seem to have great cooling solutions, Powercolor's is a bit more moddable)
    Regarding volt mods, you would have to use RBE and mod the BIOS. Card looks sweet, but they missed the boat with the VRM. I've been waiting for MSI's Lightening 5870, which will have the Volterra adjustable VRM. That card is total non-reference. Be interesting to see MSI's card WHEN it becomes available. One of my 260's is a MSI with a heat pipe cooler. Very quiet & efficient. I have been running it at 30% fan cycle at 736/1490/1215 clocks. Its the slave in my SLI and it loads at 50-65C.
    I've also found I can now run 2 different fan profiles with EVGA Precision. I've gotten a handle on those 2 hair dryers!
    Sep 2007
    has anyone successfully flashed bios of Saphire 5870 Vapor-X (rev. 2), whose core voltage by default cannot be tweaked trough MSI Afterburner?
    MOBO: ASUS Maximus IX Hero Z270
    CPU: i7-7700K @4,8ghz (1,25 vcore) (cooled by Noctua NH-D15)
    RAM: Hyperx Fury Black (2400mhz, CL15) 2x8gb @3000mhz (16-18-18-36, 1.30v)
    SSD: Samsung 850 PRO 512GB
    VGA: MSI GeForce GTX 1080 ARMOR OC 8GB
    PSU: Corsair AX850
    OS: Windows 10 (x64)
    May 2009
    Upstate, SC
    overclocked my stock fan sounded like a hurricane once it started to try cooling the VDDC's
    SYSTEM
    i5-3750K @ 4.6ghz - ASRock Z77 Extreme4 - 16GB Samsung DDR3 - Sapphire R7 370 Nitro 4GB
    Water Cooling
    EK Supremecy - DDC-3.2 w/XSPC Top -Swiftech MCR320-QP - EK Multioption 150
    Jun 2005
    Massachusetts
    Quote Originally Posted by -JJ- View Post
    Good question. My thought was to change the stock voltage through RBE. However, that may not be so straight forward if Saphire locked the BIOS chip. I'm interested to hear if anyone had success modifying the card's voltage through the BIOS.
    Sep 2007
    This is exactly what I wish to know
    Here is how bios of Saphire 5870 Vapor-X (rev. 2) looks like @default seetings through RBE.
    Attached Images Attached Images
    PSU: Corsair AX850
    Jan 2006
    New Hampshire (USA)
    I'll start with my initial thoughts on the card (VaporX 5870 which I just installed 2-days ago). It took me a few tries before figuring out what software I wanted to use for adjusting graphical settings (CCC, RivaTuner, ATI Tray Tools, etc...), after testing each I ended up using the stock CCC v10.2 along with Afterburner (mostly so I could view temps, clocks, and fan speed via my G15 but it also comes in handy for clocking). Initially I didn't like the CCC software at all (after many years of Nvidia's control panel) but once I got used to it I'm actually pretty impressed with how simple it is to use! Since I'm in grad school I haven't had enough time to run many benchmarks but I've played a few hours of Mass Effect 2 with zero issues and very smooth gameplay at 1920x1200 maxed out (which beats my old GTS250 1GB), lol! So all in all I'm pretty happy with my first ever ATI/AMD graphics card but I do regret buying the Saphire VaporX (I really wish I just got one of the reference design PCB's instead, it would make clocking much easier and will make watercooling much easier too)! I might return the card since its in perfect working condition and hasn't even been clocked for another one of reference design, should have done more homework before buying!
    With that all said I spent the last hour or so trying to figure out if anyone has modified their VaporX BIOS and was able to get control over the voltage, unfortunatley I couldn't find anything! If I decide to keep this card then I'll do my best to figure this question out (probably have to use unlocked ASUS BIOS, unless theres an easier way)? By the way thanks for posting those screenshots JJ, much appreciated!
    Noctua D14
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    LG GGC-H20L Blu-Ray
    HEAT
    Sep 2007
    Whatever may be the ending for this voltage editing saga, you really have to appreciate the cooling setup of this card. At decent OC of 950/1300 and fan set on auto, it runs cool as hell and the fan is barely noticeable even under the heaviest of loads! It is simply amazing to run games @max settings with max temp. of GPU reaching only 67 C !
    PSU: Corsair AX850
    Sep 2009
    InDiA.x GhY
    Is Rev-2 is having a blue PCB ?
    I RMAed my black PCB 5770,they forwarded me a custom designed blue PCB 5770.....& that too the voltage now cannot be changed ,through MSI AfterBurner or RBE 1.24...............
    that is the case here i think so ..... Good Luck
    Sep 2007
    Quote Originally Posted by pr@$r1g View Post
    Yes! It is developed by Sapphire, instead of AMD, as it is the case with the black PCB and Rev. 1.
    Did you try flashing your RMAed HD 5770 (custom designed PCB (blue)) to ASUS bios ?
    PSU: Corsair AX850
  18. #18
    Sep 2009
    InDiA.x GhY
    yes i did & it does work but with creepy clocks instead of 850/1200 it works @ 600/1200 ...........
    Flashed back to original .......... i think RBE is still buggy ,i tweaked the bios to 960/1250 it works but the clocks go up & down ..........
    I think volt mode for vcore & vmem is the last option to get more out of this ................
    I have already started a thread here http://www.xtremesystems.org/forums/...d.php?t=244599
    Im not able to get this locally
    where ever i ask for the above ,they show me this
  19. #19
    Jan 2006
    New Hampshire (USA)
    Well guys I've got some interesting news (well interesting to me anyway). I was browsing through newegg yesterday when I noticed there was two listings for the Saphire 5870 VaporX card, initially I had no idea why they posted the same card twice but after closer examination I realized the second Saphire 5870 VaporX card was actually the first revision version with the black PCB. Also interesting to note is that they second revision 5870 VaporX card with blue PCB just jumped from $429 (which is what I paid for it at newegg less than a week ago) to a whopping $479 Plus the new listing they have for the first revision of the card is only $429
    With that all said I ended up buying one of them (there was only 4 in stock) and it should arrive on Thursday (they were listed as brand new retail cards so I very much hope that newegg didn't just clean up some old revision one VaporX cards that got returned and now their selling them for premium prices)! I'm very curious as to how this card will compare with my current rev2 card in regards to clocking and heat levels (both at idle and while under load)? I will try to post back on Thursday night once I get home from work with some initial info on the card.
    Newegg listing for rev2 5870 VaporX
    Newegg listing for rev1 5870 VaporX
    Last but not least, has anyone here actually tested out Powercolors non-reference version 5870? I ask because while I was viewing the rev1 VaporX card last night I took a much closer look at the Powercolor card as well. I could be wrong but the PCB design looks very similar to the rev2 VaporX card (VRM design is very similar and unlike reference design). I'm curious if the Powercolor 5870 also has no ability to change voltages via software like Afterburner. Again I don't know this guys, I just realized that the PCB design is very similar?
    Noctua D14
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    LG GGC-H20L Blu-Ray
    HEAT
  20. #20
    Sep 2007
    Quote Originally Posted by Roger_D25 View Post
    Yes, Powercolor HD 5870 PCS+, similarly as Saphire 5870 Vapor-X Rev. 2 also has a custom PCB, and you wont be able to adjust GPU core voltage trough software or bios edit.
    PSU: Corsair AX850
  21. #21
    Jan 2006
    New Hampshire (USA)
    Thanks -JJ-, much appreciated!
    Noctua D14
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    LG GGC-H20L Blu-Ray
    HEAT
  22. #22
    Worlds Fastest F5
    Aug 2006
    Room 101, Ministry of Truth
    The Powercolor runs 12.016 rev bios and the Vapor-X rev 2 runs 12.019...
    X5670 B1 @175x24=4.2GHz @1.24v LLC on
    Rampage III Extreme Bios 0003
    G.skill Eco @1600 (7-7-7-20 1T) @1.4v
    EVGA GTX 580 1.5GB
    Auzen X-FI Prelude
    Seasonic X-650 PSU
    Intel X25-E SLC RAID 0
    Samsung F3 1TB
    Corsair H70 with dual 1600 rpm fan
    Corsair 800D
    3008WFP A00
  23. #23
    Jan 2006
    New Hampshire (USA)
    Well the card arrived today, what a huge disappointment! The newer rev2 VaporX 5870 (with blue PCB) has the model #100281VX-2SR, and the older initial rev1 VaporX 5870 (with black PCB) has the model # 100281VXSR. Newegg had posted the older rev1 card with black PCB (model #100281VXSR) two days ago and they had 4 of these cards in stock (one of which I purchased). With that all said I got home today I was pretty excited because the retail Sapphire box that got delivered from newegg had the model # of the initial rev1 card printed on it (it was the first thing I checked to make sure they didn't send the wrong card before I actually opened the retail package).
    So I opened it up and immediately realized it was infact the new rev2 card with with blue PCB and model #100281VX-2SR which was very disappointing and strange given that the box had the correct model # on the outside? My initial thought was that newegg maybe opened the boxes up and stocked them with rev2 cards (maybe knowing that there was some demand for the original rev1 card with black PCB). However after giving it some thought this makes no sense because they just increased the price of the rev2 cards from $429 to a whopping $479 overnight one day before I bought this supposedly rev1 card?
    It really stinks because I was looking forward to checking out and testing the original rev1 VaporX card, fortunately I was able to call newegg and they are refunding my entire payment (no restocking fee) and also paying for me to ship the card back to them (so at the very least I didn't loose any money)! Sorry to blab and on and on but I wanted to share my experience (so hopefully no one else makes the same mistake I did and has to deal with all this crap)!
    Last edited by Roger_D25; 02-25-2010 at 02:53 PM. Reason: Spell checking and sentance break up.
    Noctua D14
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    LG GGC-H20L Blu-Ray
    HEAT
  24. #24
    Dec 2008
    Ouch man. That sucks, at least they didn't make you eat the costs to ship it back to them.
  25. #25
    Jan 2006
    New Hampshire (USA)
    Yes I was very greatful for that! They handled it much better than I thought, I was sure I'd be screwed big time!
    Noctua D14
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    LG GGC-H20L Blu-Ray
    HEAT
