    X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 9 of 9
Thread: Where to get Bloodrage audio drivers for win7?!
    Jun 2007
    mars
    Hi,folks!
    I need x-fi drivers for win 7, but there is corrupted archive with audio drivers on official site, here
    http://www.foxconnsupport.com/downlo...eywords=&sort=
    is there any other place where i may get this?
    I did try to install drivers from the cd (vista), but it didn't work.
    Intel Xeon W3520 4200MHz HT
    Foxconn Bloodrage
    3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
    MSI GTX480 M2D15 850/1700/2000
    Samsung F1 1TB
    Corsair TX950W
    Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
    NEC 2690WUXi
    Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
    Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
    *New* CM 690 II Advanced Watercooled
    *Coming soon* Stacker 832 Rebirth!
    Xtreme X.I.P.
    Nov 2002
    Shipai
    there is some trick to it iirc... you have to run the vista drivers in compatibility mode iirc...
    search here on the forums, there should be at least one thread about it in this section
    Jul 2008
    the main driver are realtek HD so download the latest from them
    the creative one there will be new once soon but the last had a bug in them so not released
    Xtreme Cruncher
    Mar 2005
    What about Server 2008 R2? I've got the basic driver and the Creative console enabled, but trying to run the Creative stuff errors out - no device found.
    Bloodrage || 920 @ 3.2Ghz || TRUE Black
    3x 2GB HyperX 2000 || @ 2000Mhz 7.7.7
    2x 300GB WD VR Raid 0 || 2x 2TB Samsung F3 Raid 0
    LG 10x BD-R || LG 22x DVD/RW
    MSI GE 470 || LG 246WP
    Sonar X-Fi || Klipsch 5.1
    Lycosa || Mamba || Exact Mat
    CM ATCS 840 || Seasonic M12D
    Server 2008 R2 x64
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Sounds good with just the realtek driver to me... I've always had trouble out of the x-fi ones in the past so I never installed them with this board.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by gr8golf View Post
    meh, creative... : /
    try and see if they can help you...
    they offer this xifi emulation on realtek codecs to asus and gigabyte as well, so if it doesnt work its not a foxconn only issue and they should be motivated to fix it...
    Mar 2010
    Hello there,
    Have you checked compatibility?
    Just an FYI for you.
    It is always best to check with the software manufacturer FIRST. They will tell you if they have tested the product and the version, as well as whether or not it will work with Windows 7.
    Check out the Windows 7 Compatibility site: (There you will find out about hardware and software compatibility.)
    http://www.microsoft.com/windows/com...s/default.aspx
    There is a pulldown from which you can choose "hardware" and "software".
    There are also some great articles, instructional videos and such to help with your Windows 7 at our Springboard site:
    http://technet.microsoft.com/en-us/windows/default.aspx
    In any event a lot of the times, Vista drivers will work in lieu of Windows 7 drivers, however, it's not 100%!
    As stated previously, it's best to have the Windows 7 certified drivers installed.
    Microsoft does have an official Windows 7 Support Forum located here http://social.technet.microsoft.com/...egory/w7itpro/ . It is supported by product specialists as well as engineers and support teams. You may want to check the threads available there for additional assistance and support.
    Thanks again,
    John M.
    Microsoft Windows Client Support
    Jul 2008
    if you was to check, i had released new driver for win7 lol
    Feb 2009
    Only problem I had was with the Creative software, the Win7 drivers linked here work fine.
    Foxconn Blood Rage rev 1.1 P11
    I7 920 C0@4.018 GHz
    Coolermaster HAF
    Coolermaster V8
    Mushkin Enhanced Redline 12 GB kit @1524
    eVGA 8800GT
    Corsair TX650W
    Kingston SNV425S264 64 GB SSD
    2xWD 500GB, 2xWD 1TB
    LG LH-20A1L
