+ Reply to Thread
Results 1 to 8 of 8
Thread: F2-6400PHU2-2GBHZs Will - F2-6400CL5D-2GBNQs Won't
    Xtreme Enthusiast jedihobbit's Avatar
    Mar 2006
    Central VA, USA
    0
    Have a situation here where my HZs will run like the wind in a setup but the NQs won't even boot. Are they that much different?
    Before swapping I set the bios to 5-5-5-15-2T @ 1.95v
    System specs:
    Mobo: abit NF-M2 nView
    CPU: Opty 1210 CCB6F 0750EPMW
    HFS: zalman CNPS7000
    Memory: G. Skill F2-6400PHU2-2GBHZ YES
    Memory: G. Skill F2-6400CL5D-2GBNQ NO
    As of 04/29/11
    Celtic Spirit >> (Under Construction / WC’ed) >> Antec SX1200, MSI 890GXM-E65, PII X6 1055T, 2 x GTX 285s, HDDs (TBD), 2 x G.S. F3-12800CL7D-2GBPI, OCZ 700W Modular, XP Pro SP2
    KestrelFlight v1.0 >> (To Be WC’ed v2.0) Zalman Z7+, MSI NF980-G65, PII X4 1055T, 2 x Galaxy 580GTXs, Zalman 32GB SSD, WD V'Raptor 300GB, G.S. F3-16000CL9D-4GBTD, Zalman ZM1000-HP Plus , Win7
    Oz1a v2.0 >> XFX MDA72P7509 750a, PI X2 8870BE, 2 x XFX GTS250, WD 250GB, F2-8500CL5D-2GBPK, Tt TR2 600W, XP Pro SP3
    G.Skill USA Tech GSKILL TECH's Avatar
    Sep 2005
    0
    Try one stick at a time to make sure no sticks are defective. You may want to set VDIMM slightly lower as well. To answer your question, they are quite different.
    Thank you
    GSKILL TECH
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Mar 2006
    Central VA, USA
    0
    It appears that the mem didn't like the oc that I failed to stop before installing the mem. All is good thanks! Did the each deal and then thought about the oc and did the cmos thing.
    As of 04/29/11
    Mar 2006
    Central VA, USA
    0
    So my next question....just how oc'able are the F2-6400CL5D-2BNQs?
    As of 04/29/11
    Sep 2005
    0
    They are more geared for light gaming, multiple applications, and such but not your massive overclockers or high performance memory like the HZ.
    Thank you
    GSKILL SUPPORT
    Mar 2006
    Central VA, USA
    0
    I thought it would be that way, but I hadn't expect the overclock to have been impacted this much!
    The Hzs in the assembly would take the 1210 easily to 3.1GHz, however with these NQs I can't get over 2.6GHz.
    Whereas here they do "wonders".......http://www.xtremesystems.org/forums/...d.php?t=135578
    Is this one of those intel vs amd thing or has the memory changed that much over the years?
    As of 04/29/11
    Sep 2005
    0
    What VDIMM and frequency did you try?
    Thank you
    GSKILL TECH
    Mar 2006
    Central VA, USA
    0
    Quote Originally Posted by GSKILL TECH View Post
    Thank you
    GSKILL TECH
    2.0, 2.1, 2.2 and 677 (where the HZs work), 533, and 400(doesn't want to boot)
    I've used both 9X and 8.5X multis with 8.5 at least taking me up to 2.7GHz, however 9X at 300 is a no-boot situation with 290 and up not being stable with a 16M run of HPi.
    Thks
    As of 04/29/11
+ Reply to Thread
