If it was the fuse it would not turn on at all, sounds like you shorted out your receiver.
Double check all your connections to make sure no wires are touching or shorted.
Still in warranty ?
Most, if not all, receivers have a protection circuit. If it detects a shorted condition a relay will trip and cut power to avoid a fire. Not uncommon for a shorted power amplifier chip (final amp stage) to trigger this event. Solution=replace the bad amp chip. Sometimes catastrophic failure backwards thru the signal path so replacing power amp chip alone may not fix it plus you need to check DC bias after replacing chips. It is usually repairable. If receiver has discrete amp chips (1 for each channel) then just 1 chip to replace. Call a reputable repair shop.
Crunching For The Points!
[QUOTE=PagenII;4239997]Most, if not all, receivers have a protection circuit.QUOTE]
yep check all wires make sure none touching ive had same problem with my onkyo.. had some wires touching in the back.. go thru and make sure all wires are good before calling out for repair
- You may not post replies
- You may not edit your posts
Forum Rules
