wPrime Benchmark 2.01
-Version 2.01 updates the hardware detection method to CPUz version 1.53 (see cpuid.com) to improve support for the latest processors.
Need a Gigabyte latest BIOS?
Z370 AORUS Gaming 7,
GA-Z97X-SOC Force ,Core i7-4790K @ 4.9 GHz
GA-Z87X-UD3H ,Core i7-4770K @ 4.65 GHz
G.Skill F3-2933C12D-8GTXDG @ 3100 (12-15-14-35-CR1) @1.66V
2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black SATA3 1TB HDD,
Evga GTS 450 SC, Gigabyte Superb 720W
XSPC RayStorm D5 EX240 (Liquid Ultra)
NZXT Phantom 630 Ultra Tower
Win 7 SP1 x64;Win 10 x64
Still up at v2.00 levels, there's very little difference between v1.55 and v2.00, basically I removed some compile optimizations because these were causing the variances in the performance between compiles, there was no way to keep consistent scores between compiles using the v1.xx calculation module. The only solution was to redo the calculation module and compensate for difference in performance as best possible, they should be roughly equal for modern day CPUs, with v2.xx being faster than v1.xx for older CPUs. v2.xx will always have consistent performance between versions, that's why I prefer to continue with it.
Gonna give this one a spin, thx for the heads up Stasio and wwwwwwwwwww
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
wPrime Benchmark 2.02
-corrected a performance issue in v2.01
-submissions from earlier versions are no longer being accepted
wPrime Benchmark 2.03
We've just found that wPrime is indeed hanging on certain systems (confirmed on a fresh install of Windows Vista). It appears as though Vista would assign a different temporary directory to wPrime from CPUz (probably because wPrime was run as Admin). Consequently wPrime never found the CPUz output file and waited.
We've corrected this in version 2.03.
wPrime Benchmark 2.05
http://download.wprime.net/wPrime205.zip
-upgraded CPUz to version 1.58
some diferences in performance?
ROG Power PCs - Intel and AMD
Does version 2.05 detect a 2600K? I've tried benching my 2600K + Asrock Ex4 with version 2.05 and it doesn't seem to detect my hardware. I can run the benchmark, but W-prime does not detect my hardware. It just sits and spins. Any ideas?
Asrock Extreme 4 | 2600K | 16G G Skill | Powercolor LCS 7970 | PCP&C 910 Silencer | Crucial C300 + Intel X-25V + Raptors | D-Tek Fusion v2 | Swiftech MCR Drive 360 | HP LP2475
Umm.....yes, I understand how to override the hardware scan, but does the hardware scan work? particularly with Sandy Bridge.
wPrime Benchmark 2.06
http://download.wprime.net/wPrime206.zip
wPrime Benchmark 2.07
http://download.wprime.net/wPrime207.zip
Upgraded CPUz to version 1.59
Fixed parsing bug which would miss some DMI information
Added commandline option -run=32M and -run=1024M
Added support for checking processor count
Changed save file format to support processor count data
Made wPrime request Admin privileges when running
wPrime Benchmark 2.08
http://download.wprime.net/wPrime208.zip
Made wPrime console output to the std
Added commandline option -exit=1 to auto quit after completing test
wPrime Benchmark 2.09
http://downloads.putme.net/wPrime209.zip
Added link field in wPrime submission
Upgraded CPUz to 1.60
