X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 4 of 4
Thread: GSkill with Asus P6X58D MB...
    Dec 2006
    in the computer...
    Deciding on components for next rig...
    Comp is strictly for gaming... I will do moderate to aggressive overclock w/ air-cooling with a i7-920 and Asus P6x58. Will get the new Fermi or the ATI 5970.
    Which GSkill mem to get?
    Asus P5B-D (rev 1.04g, bios 1237)
    E8400@3.6ghz | Xigmatek s1283 HSF
    GTX 280 | 4 gig G Skill 8800 at PC2-667
    Intel x25G2 SSD | PCP&C 610W | Win7 64 bit
    DDR3-1600 CL7
    http://www.newegg.com/Product/Produc...-335-_-Product
    DDR3-2000 CL9 (Many people have been able to do DDR3-1600 CL6)
    http://www.newegg.com/Product/Produc...-254-_-Product
    Thank you
    GSKILL TECH
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Dec 2006
    in the computer...
    So, the memory in the second Newegg link would OC better? Or, would be more stable, if I were OC'ing the i7-920 to @ 4.2ghz or so?
    Well, it gives you more flexibility, but you may not need it if you're aiming for 4.2GHz. Since it is already a higher speed, you can overclock it beyond it's rated DDR3-2000 while you can't with the DDR3-1600. But like I said, if you're overclocking the CPU that much, you probably wouldn't be running the memory at DDR3-2000+ anyway.
    Thank you
    GSKILL TECH
