1. impossible to list as it gets kicked off the throne every 3-6 months..
2. Also impossible because GPU blocks are more aimed at image then cooling potential.
3. You can never have too much radiator.
4. This has is only answerable with your tollerance to noise.. Lower the FPI the better its meant for slower fans.. however GTX is king with san aces.
5. WHAT??? i cant hear you over my san aces...
4. Shazza you lost the ability to count?? lololol... Loop order is Moot.. so no it doesn't matter, unless your watercooling the sun. (this has more to do with flow... and how much heat you have inline... just try to keep a loop below 350W for every 1gpm flow.)
5. Another question on how well your hearing is...
6. Another best question that can only be answered by personal taste.
7. EWWW i hate compressions...
8. Unless you want your internals dyed brighter then a intel blue man... go straight distilled.
11. Woah... number jump... Newbies should start with cheap tubing, so they can have more to play with with less cost... while experienced vets, shouldnt be looking at this thread.
12. A drain is very nice to have.. makes your life a lot easier, along with Quick Disconnects.
13. Do not leak test the same way a vet would... We are crazy to go live after bleeding.. but we know what were doing...
14. Oh gowd... lets lose the dogs of war.. on one side we have the ever immortal TJ07, on the other.. its a borg CUBE!
15. Only if your name is Luffy and your looking for One Piece.
