Have been thinking about doing an updated guide to water cooling, but not much time to devote to it. It was previously mentioned that we should have a F.A.Q. thread - most of us said it wasn't worth the effort, since people don't read the INFO sticky that Ashraf put together for us.
Re-thinking this, and thought it might be worth a try. Maybe it will help a few people. Off the top of my head, I came up with the following questions:
1) What is the best water block for the CPU ?
2) What is the best water block for the GPU(s) ?
3) How much radiator do I need?
4) What is the best radiator?
5) Which fans should I use?
4) Does loop order matter?
5) What pump should I use?
6) What reservoir is best?
7) Should I use compression fittings?
8) Which coolant should I use?
11) What tubing should I use?
12) Do I need a drain?
13) How do I leak test?
14) What is a good case for internal water cooling components?
15) Is it necessary to speak like a Pirate to build an awesome water cooled rig?
Oops ... answering all of these questions will be about as much fun as writing a new guide. Obviously, this will be intended for the person new to water cooling, and there won't be absolute answers to all of the questions.
Any thoughts? Additional FAQs you can think of?
